Irons Logo
Anonymous Posted on Jul 31, 2012
Bosch Sensixx B25L
I have a Bosch Sensixx B25L - TDS2511GB Iron. When iron has heated up steam comes out from the side of the iron instead of the holes on the iron plate and this burns your hands when you press the steam button. Iron handle is too hot to hold, I have cleaned sole plate, added white vinegar to water filter incase clogged but problems still happen. This is the 2nd replacement i have had from Bosch as the first time it happened the iron would not heat up after time. Please advise is you know of any faults or remedies to stop the iron from burning me or can this be fixed.
  • Anonymous Mar 16, 2014
    my bosch tda 8337 iron has come loose from the iron plate
ernesto cuadra
Level 3:
Top Expert:
  • Bosch Master 12,223 Answers
  • Posted on Aug 01, 2012
ernesto cuadra
Bosch Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076056
Points
34431
See the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
  • Anonymous Aug 07, 2012
    thank you for your advice, all aspects were checked, I have now sent iron back to Bosch who are sending replacement as still under guarantee
2 Related Answers
Anonymous
  • 244 Answers
  • Posted on Jun 02, 2011
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Anonymous
  • Posted on Apr 20, 2011
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
My iron has stopped heating up although lights still flashing and stop to tell me it's heated but still cold
Soak the base in vinegar and water for two hours, shake it and see the junk come out. Repeat with fresh vinegar and water. Leave the iron in the airing cupboard overnight to dry out internal condensation. Next day half fill iron with vinegar and water leave two hours, empty. Plug in it will likely heat up again so put water in the iron and heat it up then unplug use the calc clean and shake it over the sink
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
1helpful
Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
4helpful
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 • Irons
30helpful
I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
Jun 01, 2011 • Irons
12helpful
3answers
74helpful
2answers
Bosh sensixx B25L iron spraying brown water
Feb 22, 2010 • Bosch Irons
Top Bosch Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Bosch Iron Expert? Answer questions, earn points and help others
