Laptop booting up and then shutting off unexpectedly.
I have a Gateway laptop that was started this morning and unexpectedly shut off. Now, I can't start it. Lights come on and immediately shut off. Interestingly enough, an older laptop I had sitting around I decided to bot up in the meantime started to give problems now, too. It boots to Windows everytime but shuts off unexpectedly.
  • 2 more comments
  • Anonymous Dec 16, 2008
    I have the same problem on my laptop and also on my desktop. Started yesterday now laptop doesn't start at all. Desktop boots up then shuts off???
  • mpmorin Dec 19, 2008
    I live in an area that was hit hard by the ice storm. I didn't lose power but I'm wondering if my house was getting hit by dirty power. Later that same day, the computer started no problem. I have not had the problem since. I had it cleaned out with alcohol - memory, battery connectors, wifi card, hard drive CPU/fan cover. It seems that it may be sucking up dust.
    About the MS updates. I got updated 12/10/2008 but the problem occurred 12/15/2008.
  • Dave Long May 11, 2010
    have you had any recent ms updates?
  • 111 Answers
This sounds like the cpu fan assembly go to Gateway and enter the model in the support then download the system diagram so you can remove the casing it would take me forever to type the inst. once you have removed the cover put you hand over the cpu fan assembly and check for airflow
If you are afraid to diass. your comp. take it to a pro.
Posted on Dec 19, 2008
  • Leslie Dec 19, 2008
    do u know how to open your lt. you may have had a power surge check the cpu fan then write me back
    was it plugged in? write me directly at my co. website
    www.safecompute.org
Samsung Laptop Shuts Down Unexpectedly
It may be overheating. Try using a vacuum cleaner hose on the air vents, that will help to clear the ventilation for the radiator.
Jan 18, 2014 | Samsung Computers & Internet
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
Shuts down unexpectingly when running game programs
Is the Laptop Overheating? During intense game play your Laptop will Overheat if it's not getting sufficient air flow. Try cleaning the Fan, vents, heatsing with Compressed Air, Improve air flow through the Laptop, a Laptop Cooler is a option. Try shutting down unnecessary processes, I use freeware RAZER GAME BOOSTER, you configure what you want to shut down: http://www.razerzone.com/gamebooster Remember, Your machine usually shuts down for a good reason, it's trying to protect vital components. Overheating will fry the CPU, Graphics Adapter, etc.
May 11, 2013 | Gateway NV73A17u Laptop
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Dropped my laptop. It didn't shut down or anything it ran just fine. When I turned it on this morning it would not start and prompted me to do a system restore. Started that but it didn't complete because...
When you dropped it you will have caused the Hard drive arm to contact the surface of the hard drive, damaging it.
Unfortunatly, it looks like it damaged the Boot files, Its worth a try with the recovery disc, you may need a new hard drive if it fails with the recovery disc
Sep 05, 2010 | Gateway Computers & Internet
Unexpected Shut down
Most probably that overheating is the cause of this. You might wanna buy a cooling pad and see if there will be any changes.
May 14, 2010 | Acer Extensa 4620 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
I have a Vostro 1700 laptop. Normally i would press the start button the laptop to start up the computer, but recently, when i put the power switch on on my plug socket on the wall the computer just starts...
- buttons, especially the power button could be grounded. This needs replacement and repair. You will need to contact the manufacturer for support if warranty is still active. A technician needs to be there to replace some parts
- The reason why the computer went straight to diagnostic mode is because the power button could be grounded since it's turning on automatically when plugged and when the power was disconnected the system shuts down unexpectedly. Turning on a computer that experienced unexpected power loss may result to running in diagnostic mode
- You might as well check the battery.
Dec 26, 2009 | Dell Vostro 1700 Notebook
Laptop locked up this morning. Went to reboot, Irt
Hi. Try to tap F8 during start and then try safe mode then reset it again. If this doesn't help try to clean you computer inside it looks like overheating problem.
Oct 15, 2009 | Computers & Internet
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
