Question about Yamaha HTR-5790 Receiver
Fan turns on amp does not
My yamaha amp has been stored for a year wen i use to use it I had a dvd player over top the vents and the amp shut down one day, I have now purchased high perfomance polkk audio speakers and would like to use my amp. I pulled it out last nite, it turned on and off fine, now this morning I plug it in and it turned on then i turned it off, now trying to turn it back on, only the fan starts up I get no other indication of power. I know I am using a a different powercord could this be the problem?
SOURCE: Yamaha RX-V1500 Shuts down after 2 seconds
Asouth, I'm curious if you have solved the problem with your receivers? It sounds like the same problem that I am having with my RX-V1500. I would appreciate any response that you would have to this inquiry.
Posted on Jun 06, 2007
  • 151 Answers
SOURCE: No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
SOURCE: Yamaha rxv 595 receiver shuts down when volume is increased
THE SPEAKER WIRES ARE REVERSED.... On the receiver the red side is always positive and black is always negative.
change + to - or
change - to + on one or more speakers.
positive side--------------------negative side
red --------------------------------black wire
gold wirew/silver--------------silver wirew/gold
white lined----------------------non-white lined
Posted on Oct 30, 2008
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
  • 118 Answers
SOURCE: We have a Yamaha RX -V565 and after listening to
chances are youve got a short at the rear of the receiver. look for frayed speaker wires touching the chassis of the stereo. use a flashlight. it only takes one tiny hair of a wire to short it out
Posted on Nov 03, 2009
Receiver turns off after DVD is turned on. Clicking noise. Check speaker wires
It's a issue with alot of these Receivers I personally had this issue on my Receiver. the issue is a ground Fault the protection mode for over current in some of Yamaha's and HK receivers are the Two main Relay's if the Ground inside the amp is lose or is causing a Ground Loop this will happen. as you turn on the DVD there is a slight leak of Positive current tru a bad Capacitor and Resistor on the DVD player causing the Ground to send a instant burst of -Vcc to the Amp's ground setting the Protection mode on. but because it's not caused by the Receiver it self sometimes it looks like the Amp just shut it self down. In better words Try to Ground the DVD before you hook up again. use the Outlet Ground also if you use a 1K resistor on the ground wire it will help to keep any noise from coming in. Let me know. Marcelo Good Luck.
Aug 06, 2011 | Yamaha RX-V663 Receiver
When watching a movie on DVD player the Yamaha shuts down and when you power it back up and tell you to check audio cable
Do as it asks.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 11, 2011 | Yamaha RX-V361 Home Theater Receiver
Hey got a yamaha rxv650 amp in good nick that has stopped switching on. Been great 4 years love the unit, normally has that secondary click wen u push the on button but has just stopped. Any ideas and does...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
Feb 28, 2011 | Yamaha RX-V650 Receiver
My Sony Vaio VGN-CR320E turns itself off all the time. I have already formatted it, but the problem continues... What can I do?
IS it getting hot. Check the fans. It'll shut down if the fans aren't running and everything gets to hot. You might be able to use compressed air and blow out your vents and fan blades. Dust builds up and limits air flow causing extra heat, and then shut down. IF your running your laptop on your lap, make sure your not covering any vents or air flow. Its easy to do and not realize it.
Feb 18, 2011 | Computers & Internet
The amp/receiver JVC RX DV31 is displaying Overheat
Turn off all power, really should wait several hours for the capacitors in side to discharge. Remove the four screws from the sides and three screws from the top cover. Lift from the back pivoting towards the front to remove the cover. Inside you will find three small fuses. One fuse by itself and two close together. The fuse you need to replace is the fuse closest to the rear of the set of two. It is located next to the power clip for the fan. I believe the fuse is a 120v 2 amp fuse but check the board to be sure. if the fan is not working (you should be able to hear it) it will need to be replaced or if the power is not getting to it, a new power source added. I used a 12v 50ma adapter from the junk box.
Oct 22, 2009 | JVC RX-DV31 DVD Player
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Protection
doe sthis do it on all dvd or just 1 is fan out on it in well vented place
Jan 27, 2008 | Samsung HT-DS610 System
Auto shut down of unit
the audio amps may be overheating and shutting down. a lot of electronic devices don't receive heat sink compound when being assembled and the heat doesn't transfer as it should. Try cooling the unit either in a plastic bag in the refrigerator or placing it in a cool airstream directed at the rear of the unit. If it's in a stack of other electronic devices, place something between the units to allow air to circulate. I hot-melt glue tinkertoy wheels to the bottom of the units myself to separate them.
Nov 24, 2007 | Yamaha DVR-S200 DVD Player
Yamaha HTR-5790 Receiver Logo
48 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
