Question about Food Mixers
Classic mixer changing speeds by itself ?
On slowest speed and then all of a sudden speeds up and splashes flour all over the place. Help
  • 1 more comment
  • santo41 Jan 03, 2009
    KitchenAid classic mixer KSM90BU, it's about 7 yrs old and rarely used. THX Mike
  • santo41 Jan 04, 2009
    Thanks, I will give it a try.
  • Rick Belanger
    Rick Belanger May 11, 2010
    Hi. Please give us a little more information so that we can better help you.. What is the manufacturer's name? What year and Model # is it? I can imagine that you need an answer quickly. Messy indeed. ricardok45
  • 135 Answers
Contact Kitchenaid Parts and order a new speed switch. Be prepared to wait a month for it to arrive. It's relatively easy to replace. Be sure to unplug the mixer first. Make note of which wire goes where! If the switch goes bad again in the future, buy a different brand of mixer. ricardok45
Posted on Jan 03, 2009
Kitchenaid mixer will not start
The model number shown is for the Professional series which does not have a separate rear cover. Below are links to KitchenAid mixer Service Manuals:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 13, 2014 | KitchenAid KP26M1X Stand Mixer
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
I have a KM800 and the speed setting doesn't work properly, on slow it will go fast then slow and doesn't speed up and slow down as it should. is this repairable, as it's bloody annoying when you disa
Hi Emma,
Not going to be much help here to be honest. We have the KM020 and this is the only problem we have had with heavy machine use in 4 years - and a minor issue at that.
This place is good for spare parts http://www.buyspares.co.uk/
If you're in the UK, you can call this number 02392 392 333 and give them your post code, they'll let you know who the local service agent is.
All the best,
Dec 17, 2011 | Kenwood KM800 Major Classic Stand Mixer
My classic KA mixer will not start on speed position one or two. It will start if I move the the speed knob to 3 or 4. I then can use any speed. This isn't normally a problem unless I forget and start...
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 08, 2011 | KitchenAid K45SS Classic Stand Mixer
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
Hello, My mixer will not change speeds. IT looks like the handle used to change the speeds is bent. do you konw where i can take my mixer in for repair? I am located in Desoto, Texas 75115 area.
The phone number for Kitchen Aid Counter Top Appliances is
1-800-541-6390 8-8 EDT M-F and 12 - 5 p.m. Sat They should be able to give you a local authorized repair place.
Oct 22, 2010 | KitchenAid K45SS Classic Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The mixer rpm is too fast
No change available. The motor speed if fixed and the 3 speed transmission has fixed gear ratio's. Look at the new HL300 model. It has a stirr speed which is slower than first speed.
Does your mixer havea safety cage? If not, you will need to install one before too long , or the machine will not comply with current safety standards. Put the cost of the safety kit towards the HL300.
May 26, 2009 | Hobart D340-6007 Mixer
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Speed control not work - constantly on high
The resistor will have failed. The A701 replacement is a 450 ohm 15W or 20W wirewound resistor. The capaicitor also can fail if the resistor has gone. It is a mains capacitor 0.1 microfarad. The modern mains capacitors are better to use than the old electrolytic type that were originally in the mixer.
Jan 01, 2008 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
156 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Food Mixer Expert? Answer questions, earn points and help others
