Question about Epson Stylus C86 InkJet Printer
My Epson R1800 keeps resetting itself
There's something going on and I can't figure it out. My Epson R1800 keeps resetting itself. I think . Here's what I'm seeing..... I could be sitting at my desk, then the R1800 go through a cycle all by itself. I would hear the "bleep" from my PC as if I unpugged the USB cable and reinserted it. It would then come back on. This also happens sometimes during a print, and the printer would eject the print halfway. I changed USB cables, I changed the USB port, I unistalled and reinstalled the Epson software..nothing changed. Any idea what's going on?
  • 1 more comment
  • kensel Jun 22, 2008
    I have the same problem as Takayama with the Epson R1800. I finally figured out that it was a bad power switch. If I wedge a small screwdriver under the power switch to apply prissure to it then the printer will work just fine. I think having it fixed would be to costly unless I could take it apart myself.
  • Trailshooter Oct 25, 2008
    I've had the exact same problem on my R1800, and 'wedging' something under the power switch (I'm my case, a piece of paper folded over several times) does the trick. Since doing so, my printer is working great. I agree that having the switch fixed would be more of a hassle than working with the 'wedge'. ;-)
  • Anonymous Mar 18, 2014
    We have purchased a UV printer with a moving flatbed that is based on the Epson R1800 printer internals. But when we are trying to print something out via the PC(XP) that is running with the RIP software we cannot get it to print and the print head goes one time to the left and then back when afterwards it reads Flat Position Error and two lights are blinking. We downloaded Epsons EPROM software and tested the printer to find that is has a Fatal Error 54 and in the description of the error reads: "LD roller initialization error"
    What can we do and what parts should maybe be replaced?
    Sincerely Emil
    President:
  • 2,961 Answers
You have done all the usuall checks, but you may have a usb power problem, try the printer without any other usb peripheral in and see if it stays connected. If not, then the usb connection or workings in the printer may be faulty and keeps disconecting, hence the bing bong as it re connects to windows. You may have faulty hardware, leave the printer disconnected from usb and mains for 15 mins or so then try again.
Posted on Mar 18, 2007
Parts inside your printer are at the end of their service life. See your printer documentation. red lights flashing alternate . Cannot use printer
Hello, take a read of this link regarding the Ink Pad Reset utility from Epson, I see the R1800 is included.
http://www.wasteink.co.uk/epson-ipr-reset/
Regards
nicam49
Oct 30, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
The message says parts inside the printer are nearing the end of their service life. What should I do?
This message means that the printer thinks the waste ink pads are full and so
> it refuses to print until the pads are replaced and the waste ink (protection)
> counter is reset.
> In practice the pads will not be full if this is the first time you have
> received the message so all that needs to be done is to reset the counter. Next
> time you must replace or clean the pads.
> Go to http://www.ssclg.com/epsone.shtml and download the utility.
> Install it, run it and exit it from the main window, now go to the icon in the
> system tray and right click on it. Select waste ink or protection counter and
> select reset. If this gives trouble then uninstall the Epson status monitor and
> try again (you can install the status monitir again afterwards).
> The irony is that the more you use an Epson printer the more reliable it will
> be (due to the heads being kept in good condition) but the people that use
> their printer most will get this message earlier than others. Some people never
> see this message. It is a good printer and well worth the effort of doing this
> at no cost.
> Tony
> MS MVP Printing/Imaging
The SSC service utility won't reset the R1800 counter.
The Epson service program is needed and can be downloaded from:
http://www.2manuals.com/
The R1800/2400 service manual can be downloaded from that site.
If you want to have a go at replacing the pads, then instructions are in
the manual.
Oct 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 paper and ink lights are blinking
See status monitor? Is service required? Reset waste ink, Find resetter at indoreset.blogspot.com
Jun 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson R1800. Printing preference does stay on "Text"
hello there. access the printer settings from the epson software utility, and change the settings there. be sure to save your changes.
Nov 27, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper and ink lights blinking - no power light flashing at all - can't do anything on our Epson R1800 printer... can you suggest something to try? have been doing a lot of head cleaning due to bad nozzle...
Try doing a printer check by doing the steps below. If it doesnt work, then try to call the printer manufacturer for more advanced solutions or information
  1. turn off the printer and disconnect it from computer
  2. place a plain sheet of paper
  3. press and hold down the paper feed button, then press and release the power button. Continue holding down the paper button until you see the power light flashes
  4. if it prints a test page it is working fine, the problem might be the computer settings, printer settings, software or printer application, or cables, otherwise the problem is the printer itself
Oct 13, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 Photo Printer
thanks, will post on the original post only, so please don't reply here
Jun 03, 2008 | Epson Stylus Photo R1800 InkJet Printer
R 1800
where can i get a print head for my epson R1800 printer?
Mar 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Magenta light blinking on epson r1800e....
Read the manual, says something about turning off for 30 seconds and bac k on again will reset
Jan 05, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
380 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
