Excessive shaking of machine during use - Washing Machines
  • Washing Mach... Master
  • 3,463 Answers
Check that the m/c is perfectly level, and that it is not overloaded and that the load is not out of balance.
If all these points are o/k,then I would say that it may have a broken or loose counter balance weight, a broken drum retaining spring, or worn or broken suspension.,you will have to physically look for these parts inside the m/c.
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Rear shaking during smog test
Out of balance tires or a bent rim.
Apr 18, 2013 | 1994 Mercury Cougar
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Excesive Shaking during spin cycle
Your washer has self adjusting rear legs . Tilt the machine foreward and look at the back legs . If one is stuck in , use a screwdrive and pry it out till both legs are in the out position . Set washer back down slowly and the rear legs will automatically adjust .
May 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
hi thanks for the question is the washer on the main floor on a wooden floor if it is re level washer next pull washer towards you tipping towards you lift from floor a few inches and let drop to floor this will re level the back legs thanks the appliance doc
Mar 17, 2008 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
