Question about i-mate JAM Pocket PC
Pocket pc internet explorer is not working properly. while giving command to browze a web address, message appear 'the page you are looking for cannot be found'
    President:
  • 2,961 Answers
Assuming the site you are browsing is not the faultand your internet connection is up and running, there will be a setting or option in internet explorer to delete temporary files and cookies. Run this cleanup as you probably have some corrupt cookies which when you start to view the web page will be used to load the page quicker from the cached memory. close down i.explorer and open it u again and try browsing.
Posted on Mar 18, 2007
Internet Explorer cannot display web pages!
have you got an IP address? go to run>cmd and type IPCONFIG and press enter
If the IP address starts with 169. then you have no connection to the internet or your router
Have you restarted both devices (PC and router) ?
Sep 01, 2011 | Computers & Internet
Sometimes when I click on the Internet Explorer icon, and error message appears in front of a blank web page. The error message says "Internet Explorer has stopped working. Click to close program". When...
Try a scan with your virus scan, then with a malware scanner, i use Malwarebytes.
I would then use CCleaner, use the registry cleaner also.
This will clean out all your temp files, and remove any registry errors that may be causing IE from starting properly.
You could also use Firefox, or chrome as your browser if this does not fix it
Sep 05, 2010 | Microsoft Internet Explorer 8
THe computer appears to be connected to the
hello
In this case please upgrde your internet explorer or try to install mozilla firefox and you can try.
when ever you face this issue check the ipaddrerss in command prompt start- run - cmd- ipconfig should get the valid ip[ address and run one command in cmd ie ipconfig /flushdns
and then try to access internet
delete all the temp files and cookies for internetr explorer
let me know the results
Mar 17, 2010 | HP Pavilion dv4000 Notebook
I connect to wireless network but Internet explorer won't open. It then says "The page you are looking for cannot be found"
hello,
There is not connection between the wireless network and the internent... so make sure there is by ensuring that the IP addresses are properly entered and cables rightly connected
Sep 19, 2009 | HP iPAQ RZ1710 Pocket PC
When I try to open any webpage, I get this message: "Internet Explorer cannot display the webpage". Nothing will open.
dear,
something is wrong with ur internet connection. are u using dialup or dsl or other.????
what so ever, in any case u have to check the internet connection...if the souce is ok then all are fine and will go finely..
regards,
if it fix the issue then rate it...
Apr 17, 2009 | Dell Computers & Internet
I cant get on the internet,
Try to set your IP address to automatic then afterwards, go to Run and type "cmd". A command prompt window will appear, type the following commands:
ipconfig -release (press enter)
ipconfig -dnsflush (press enter)
ipconfig - renew (press enter)
after typing these commands, close the window and try to browse the internet. If the same thing happens,restart your computer and try browsing the internet again.
Mar 19, 2009 | Computers & Internet
I am connected to the internet and on msn but when i try to go on a web page it says internet explorer cannot display the webpage.
This could be only one of two things:
1) Your internet is OK, but the page you are trying to access
is bad
2) Your internet is not connected, but Internet Explorer is loading
MSN from an old cache on your hard drive.
If a single page is bad but you Internet is connection is OK,
then you should be able to get most other pages.
Try:
www.google.com
www.wikipedia.org
www.yahoo.com
www.ebay.com
www.microsoft.com
etc...
If, on the other hand you get nothing but MSN,
you have no internet connection !
To test it out:
Go to the DOS(like) command prompt, by clicking:
START => All Programs => Accessories => Command Prompt.
At the command prompt type: ipconfig /all
Look at the report, find the network adapter you are using
(if you have more than one, e.g. LAN and wireless)
and look for the value of the "IP Address"
This should reflect the address assigned by your Internet
provider, or the address of you personal router if you have
one:
A typical router address = 192.168.1.1, for example
A direct connection could be = 24. 153.14.1 or any other #
BUT
if the IP address is all zeros = 0.0.0.0
then you have no connection to the Internet.
If you have no connection (0.0.0.0) then type:
ipconfig / release
ipconfig / renew
ip config / all
If this does not fix the problem, i.e. return a non-zero
IP address,
Run the network setup wizard from the control panel to
repair your network settings.
Also reset your external router (turn it on and off)
if you are using one, and check with your IP provider
to make sure that your account is still valid.
(They will disconnect you if you owe them money
or if they have made a clerical error)
If you do have a non-zero IP address, but your
WEB browser still does not connect,
type at the command prompt:
1) Ping www.google.com
2) Ping 72.14.205.104
Compare the results.
If the first PING does not work, but the second one does,
then your address for the DNS (domain name server)
is not setup correctly. You can reach Google directly,
but you have a problem resolving the GOOGLE name to
its binary address, which is what a DNS does, but you
are not reaching the DNS server.
At this point you may want to contact your IP service
provider (tech support line) and he will walk you through
repairing your Internet connection, or send out a tech
in the case of a hardware problem.
Hope this helps,
please rate my answers,
Martin
Jun 14, 2008 | Toshiba Computers & Internet
Internet Explorer won't launch after a hard reset
Is it picking up a good IP address? Are the access points encrypted? You would need to set up the Wi-Fi on the PDA to the specifications of the WAP. if Internet Explorer is not loading, I suspect that there is a problem either with the image in ROM or else with the part of the RAM which is used to hold user data for Internet Explorer. Have you recently upgraded the ROM? The upgrade may not have worked properly perhaps. Maybe try a reflash of the ROM image. Do you get any error message or does the operating system go round in a loop and never come out?
Sep 14, 2005 | HP iPAQ H5450 Pocket PC
Pocket e800, Internet Explorer problem
The presumption that your Wifi Compact Flash Card work with Windows Mobile 2003 is higher than working with Windows Mobile 2002. The new Windows is supporting much more hardware than the old one.
Sep 08, 2005 | Toshiba e800 Pocket PC
i-mate JAM Pocket PC Logo
154 people viewed this question
Top i-mate Computers & Internet Experts
Peter Dragonetti
Mohamed Ismail
Mohamed Ismail
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
