Question about Microsoft Computers & Internet
INF file textsetup.sif is missing
Barawako@hotmail.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
His behavior may occur if any one of the following conditions is true:
  • Your Windows XP CD-ROM is scratched, smudged, or dirty. Clean the Windows XP CD-ROM with a soft cloth, insert it in the CD-ROM drive, and then click OK.
  • Your CD-ROM drive is not working correctly or the CD-ROM might be vibrating too much for the laser to accurately read the data. For more information about this problem, see your hardware documentation or contact the CD-ROM manufacturer.
  • If you are using multiple CD-ROM drives, your computer may be trying to locate files on the wrong drive. If your hardware has a feature to disable CD-ROM drives that are not being used, disable the CD-ROM drives that you are not using.
  • Your computer is over-clocked. Because over-clocking is very memory-intensive, decoding errors may occur when you extract files from your Windows XP CD-ROM.
  • Try to use the default clock timings for your motherboard and processor. For more information about how to do this, see your hardware documentation or contact the motherboard manufacturer.
  • Your computer has damaged or mismatched random access memory (RAM) or cache memory. For example, you might be using a combination of extended data out (EDO) and non-EDO RAM, or different RAM speeds.
    Decoding errors may occur even if Windows appears to be running correctly. These errors occur because of the additional stress that is put on your computer when Windows tries to extract files and to access the hard disk.
    To determine how to make your computer cache memory unavailable while you are running the Setup program, see your hardware documentation or contact your hardware manufacturer.
  • Ultra direct memory access (DMA) is turned on in your computer's CMOS settings, and the data is moving too quickly.
  • Change from DMA mode to Processor Input/Output (PIO) mode to lower your data transfer rate. If this does not resolve the problem, lower your PIO mode settings. The higher your PIO mode settings are, the faster your data transfer is.
  • You are using a third-party memory manager.
  • There is a virus on your computer.
If you continue to receive this error message, copy the i386 folder from the CD-ROM drive to your local hard disk, and then try to run the Setup program from your hard disk.
Posted on Dec 15, 2008
Inf file txtsetup sif corrupt or missing status 256
64-bit central processing unit is one that can support a higher amount of system resources than a 32-bit counterpart.
It has the ability to both recognize and use more amounts of available system memory to go along with its faster processing speeds.
If you want to install a 32-bit operating system on a computer with a 64-bit processor, you can--but you won't be taking full advantage of what your system has to offer you.
Place the installation disc for your 32-bit operating system in your computer's disc drive.
This can be one that you've purchased, as in the case of Microsoft's Windows operating system, or one that you've downloaded from the Internet, in the case of the Linux operating system.
Shut down your computer. Once completely off, turn it back on again.
Click "Next" to continue through your 32-bit operating system's setup program.
You will be asked to read the "TOS," or terms of service.
This is important legal information that you should read in detail, as it informs you of exactly what you're agreeing to by installing this operating system.
Specify any settings changes you want to make to the way your operating system is installed.
From these screens you can also input personal information into your operating system, such as your name or business information, which will save you the trouble of having to do it later when you install utilities.
Click "Install." The 32-bit operating system's setup program will format your hard drive, erasing all data on it.
It will then place the necessary operating system files on your computer.
This can take an hour or more depending on the operating system being used.
Once this process is finished, allow your computer to automatically restart.
http://zone.ni.com/devzone/cda/tut/p/id/5709
Sep 12, 2013 | Computers & Internet
Problem with boot from usb drive
make sure the usb flash not remove or move through installation winxp
if you do
you must reinstall new copy of win xp on usb flah then try agin to setuo windowsw from it
Dec 04, 2012 | Computers & Internet
Hi, i have a problem with my computer. When i boot it, something different happens almost every try. Sometimes, nothing happens and there's a black screen. Sometimes, it says that windows cannot run...
Find folder name: i386
and go to file txtsetup.sif
copy txtsetup.sif from I386 and paste in flash , next rename I386 to $WIN_NT$.~BT .Worcked 100%.
Apr 08, 2017 | Gigabyte GA-7N400-L Motherboard
I have multiboot setup on my system with Windows XP as primary and Windows 7 as other O.S. I mistakenly corrupted Windows XP. Now when I start it, it doesn't start and shows errror about "NTLDR". I tried...
when you dual boot win 7 and xp win 7 has to be the 1st 1 installed then xp or a corruption will accur .they have a fix for this on the microsoft database.it will get your xp install going.
Aug 29, 2010 | Mozilla Firefox
INF file txtsetup.sif is corrupt or missing status 14
LOL....I'm in a similar Windows boat that is sinking fast. Also using Ubuntu from a USB drive! Anywhoo....I got extra copy of XP I don't need anymore. Contact me if you're interested jh5637@gmail.com
Feb 12, 2010 | Sony VAIO Digital Studio PCV-RS420 PC...
I have a winfast com, was trying to reformat useing cd that came with com,starts to run cd, then says INF FILE TEXTSETUP.SIF missing or corrupt setup cannot continue..How do I get the file back on com?...
go to www.isohunt.com and download an oem verision of the os you are trying to install. Use the product key on the sticker on your computer case. Make sure you have another computer to download the network card driver if you are using xp or older
Nov 15, 2009 | Computers & Internet
My hard disk is detect but i can't install OS . It shows the following error: corrupt or missing INF file txtsetup.sif status-8192
You may need to go to the microsoft website, download the recovery files and make discs.
This sucks, but as I found, this may be the only way.
If you are able to boot into safe mode that may help.
If you have the OS disc you can do a recovery.
Jul 08, 2009 | Computers & Internet
Missing INF file?
here are instructions on using the Mcafee Removal tool.
http://service.mcafee.com/FAQDocument.aspx?id=107083&lc=1033
May 31, 2008 | Mcafee WebShield 3100 (EPL310ANA300)...
Computers & Internet Logo
541 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
