Question about Sony KP-61HS20 TV
Blurry video Hello, I need help troubleshooting this tv. All the video (DVD, video, cable, etc.) looks very distorted. Almost like the screen is concaved. I see "shadows" of different colors as if all the colors of the crt aren't lining up correctly. Someone told me of a "prizm" may be going out. I know what a prizm does but not too sure how it relates to tvs. I'd appreciate any advice. Thank you.
    President:
  • 3,130 Answers
You got some wrong advice I am afraid. Hope it was not a Tech that told you this LOL As i would never call them again!! LOL No such thing as that in a projection TV set. Your problem is the convergence IC's inside the TV set, on a printed circuit board. Both will need to be repalced. If you have some solid state repair experience, you could unsolder these IC's and reinstall new ones, but if you do not please play it safe and call in a pro to assist you in this repair. Good Luck.
Posted on Apr 02, 2007
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
The left side of screen is blurry.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
KP-43170 Sony Projection TV is blurry
Try this site www.my.electronicshelponline.com they have list of free schematic diagrams/service manuals including repair and troubleshooting tips. Good luck. Hope this help.
Jan 26, 2010 | Sony KP-51WS500 51" Rear Projection...
The picture is distorted and blurry
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Componants in back don't seem to work, HD cable,
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Oct 22, 2009 | Philips 55PW9363 55" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Sony KP-61HS20 TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
