Question about Sony KDL-32S3000 32 in. LCD Television
Sony KDL-32S3000: Sound is fine, Picture shows White Screen
When I turn the TV on, it takes a little time to warm up, then I get a white screen with some thick vertical white bars across the screen.
Any help would be great.
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
tvservice306
  • 458 Answers
SOURCE: lines across tv
try cleaning T-CON Board to Lcd panel cable
Posted on Aug 19, 2009
roety
  • 585 Answers
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Oct 24, 2009
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 60 Answers
SOURCE: How easy is it to repair a POWER FAILURE TO SONY
Usually it takes a little knowledge of basic electronics and some soldering skills. If you have these, then it never hurts to try to fix it yourself. Its already not working. Just make sure to work safe, unplug before working on it and close up before turning on. If you think its a power supply you might be able to see some blown capacitors, or you might get lucky and find a blown fuse inside.
Hope this helps
Posted on Jan 08, 2011
Testimonial: "Elrapido considering tome of day but as he said a little knowledge is a dangerous thing! - Guess I'll be off to Maplin to get a soldering iron"
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
We purchased a Sony KDL-46W3000 LVD TV in May 2008. Just recently the left side of the screen has started having problems with hortizontal grey bars and white lines and the screen jumping around when the...
Hi I have an old school solution for your problem with your tv. Hit it!!!!! When you turn on your tv, go to it and lightly tap on the middle of the left frame. You should see it affect your screen. Do it until your screen is perfect. Hope it works.
Jun 22, 2011 | Sony BRAVIA KDL-46W3000 Television
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony KDL-40V2500 Screen is white
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
Jan 29, 2018 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Sony KDL-32S3000 32 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
