Question about RCA P46924 46" Rear Projection Television
TV will not turn on
When trying to turn TV on for last week or so, had to push button (remote or on the set itself) at least 7-8 times. It would finally come on. Then yesterday while watching it, it just made a loud noise, and went off. When I tried to turn it back on, it came on for a few seconds, made the loud noise, and went back off. Now it will not come on at all. It is an RCA Home Theater. Made in 1992. Model #P46130W1C. Any ideas?
  • Diane Watts Mar 18, 2007
    model # is P46130WK
    Scholar:
  • 150 Answers
Probably needs a new HV Splitter block, they are very difficult to replace and can usually be accessed thru the front behind the speaker grill and behind convergence board.
Posted on Jul 27, 2007
SOURCE:
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
TV scrolls through inputs and menu after turning on. Will not stay on any input.
Main system control memory IC is faulty. Replace it. Contact any service technician. http://electronicshelponline.blogspot.com/
Mar 25, 2015 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Tuning
I assume model number here is correct--if set is scanning either just up or just down in channels that is an issue with the related button on the set itself.
I am going to take the time to explain here as I want to help you.
Let us say for example when turned on set scans UP constantly thru the channels and will not stop. Remote seems not to work and has no effect on this.
What you have in this case (if scanning down different button) is the up channel button on the set is BAD. It may look perfect but it is the cause of this (trust 30 years of TV repair here).
Each button on the set itself has a tiny micro switch than when the button is pressed acts to perform that feature and when released stops.
Keyboard (the button array) has priority over the remote--hence the remote cannot stop this action.
The tiny switches fail in exactly this way--instead of when released stopping they still try to function.
This is rare but I have seen in a few hundred sets this kind of problem--be grateful it is not the vol up doing it.
How to prove and or solve this issue?
Someone needs to gain access to the pc board with the buttons/switches and disable the (channel up or down) switch causing this problem--most switches will have just two pins to unsolder to do that---may be a few more pins for mounting but only two for the switch.
Many sets if the keyboard is up front also have the remote receiver there so you if that is the case cannot just disconnect the board.
With the correct switch (push button) eliminated out of circuit the set will work normally with the remote.
Repair: either locate and replace the entire tiny board or just leave the offensive button disconnected and use just the remote for that function.
Please, if you have questions make a comment here (make a comment button) and I will try to help.
SD TECH (TOP RATED EXPERT ON THIS SITE FOR LAST 7 WEEKS)
Apr 30, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
Samsung SPN4235 has a mind of its own
Honestly,your TV should be still under warranty right?I would have Samsung fix it. TV had a serious problem from the beginning.
solutiondoct
Jul 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
RCA P46924 46" Rear Projection Television Logo
198 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
