Question about Compaq Armada E500 Notebook
Replacing Laptop LCD Screen
Apparently my laptop received a hard knock from somewhere and the LCD screen has cracked internally. Everything else seems to be working and I have the opportunity to pick up some other laptops (same model) being sold for spare parts pretty cheaply. May even end up with a couple of working models, but how do I replace the screen? I've taken the screws out of the hinges but the next step is not obvious to me.
Allan
    Scholar:
  • 149 Answers
You'll need to remove the screws holding the screen bezel (the plastic around screen) on...they'll probably be under little circular plastic or rubber covers....gently pry these out as they'll go back in place when you reverse the procedure....should be four of them....Gently pry the bezel away from the main screen housing ...once thats done....you'll need to unscrew the screws holding the screen onto the hinge plates...(again should be 4 of these)...screen should now be free
NB be careful when screwing in the new screen to the hinge plates as overtightening can sometimes crack the screen
Posted on Dec 15, 2008
Dropped Lenovo T400. Turns on to black screen with on cursor or anything. Please help!
chances are that with the impact the LVDS cable got disconnected from the back of your LCD screen , or worst your laptop screen is internally cracked it isn't visible from the ouside . if so google for Lcd screen parts for your laptop model . laptopscreen.com LAPTOP SCREEN from 34 99 replacement LCD screens Repair Tablet Acer Apple...
Aug 31, 2015 | Lenovo Computers & Internet
Section of LCD display will not show
Assuming you have tried altering display aspect ratio and or resolution it may be that the laptop received a knock and the ribbon connector between screen and laptop has dislodged or even split or torn.if there is a fine crack on the screen or it received liquid ingress spillage then you may need to replace screen...these are quite often sourced off eBay.an engineer will typically charge something like £75 - £100 to source and replace screens but if it is touchscreen much more.
May 04, 2015 | Computers & Internet
No backlight on laptop LCD screen
The only solution I can think of is that your 40pin cable from the motherboard to the screen is damaged. They do fail just through use (opening and closing the laptop lid can put strain on the cable) Try replacing this cable.
Leon
Feb 09, 2013 | Sony VAIO Computers & Internet
Screen replacement/screen is cracked
You can get a replacement screen from this WEV site.
LCD screens and Inverterswww.lcdparts.net
Jun 14, 2012 | Acer Aspire One PC Notebook
Help with LCD screen
Replace the LCD or the laptop. It is not repairable beyond doing those things.
Jan 07, 2012 | Toshiba Satellite 2400-S201 Notebook
Cracked screen, black patches, rippled screen
Hi in this situation you should change the screen once it is crack, and if you still see the black part on the screen you can adjust the display using the hardware control management
if you please with my answer give me a vote thank you hristol173
Mar 29, 2010 | Dell Inspiron E1405 Notebook
Lcd screen partially paralyzed
The problem is either the LCD display, or the ribbon cable/connector.
The laptop must be taken apart testing the lcd ribbon cable, replacing it or re-fitting it in place inside the connector.
If ribbon cable is ok, then LCD panel is faulty.
If problem disabbears when you push the laptop case, then it is probably the cable.
Go to a reliable computer repair shop and mention the problem, the cable is worth just a couple dollars, and the labour is around $80.
Aug 26, 2008 | Compaq Presario Notebook
Possible Crack/Spillage in LCD Screen
I'm afraid you need to replace he LCD screen of your laptop. Replacing LCD screens is a bit complicated, that I suggest you send it to the Manufacturer's Service Center if it is still under warranty to avid voiding your units other warraty.
Hope this helps.
If it does, please vote. Thanks.
Apr 29, 2008 | Lenovo 3000 Y410 Notebook
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Laptop screen
is the color building up in one place and fading in another, or just fading all over? if its building in 1 spot i would suggest you have a very thin hair line crack acros the screen somewhere, if its completely fading, i would suggest the LCD converter under or behind the screen under the beizel is failing, in which case you should take to a computer tech to dismantle and test
Dec 05, 2007 | Computers & Internet
Compaq Armada E500 Notebook Logo
85 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
