Question about Sony STR-DE845 Receiver
Sound clicks off unless I pull on the speaker selector knob
The sound on my reciever recently began cutting off unless I pulled the speaker selector knob one way or another. Then the sound quit all together. I took out the little circuit board connected to it but can't tell if anything is wrong with it. The main power button is also on this board and hasn't worked for some time now (have to use remote to turn it on) Do you think this board is bad. And if it is can I order another one? Any help would be greatly appreciated.
    New Friend:
I have the exact same problem! Video goes into receiver and out of the monitor output perfectly. No sound is coming out of any speakers. My A, B, A+B, off switch is really sketchy, and my main power button also doesn't work. I would love to know if you found an answer to your problem! I am thinking about getting a soldering iron and making sure all connections are sound but don't really want to without knowing the exact problem. Did you ever fix it?
Posted on Feb 27, 2014
    Problem Solver:
  • 5 Answers
I bent the leads slightly so the 2 boards seated in more tightly together...the male plug leads. good luck.
Posted on Jul 27, 2007
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
I'm getting no sound from my htr-5450 reciever
Check the "speaker selector" on the front panel. Make sure A, B, or both are lit up. Also, make sure the "6 ch input" is"off" it's a button right below the volume knob on the right If it's still not working, post a comment and I'll help you troubleshoot further. Hope this helps
Jun 30, 2009 | Yamaha HTR-5450 Receiver
Alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
Feb 10, 2009 | Alesis M1-Active MkII Main / Stereo...
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Clicks when powered on and off; only faint sound from left and right speakers
You may not be using an active input to test. Try attaching an fm antenna and using the tuner. Sone inputs are set to digial and will not make sound with the analog input. The input selector does turn it on. Saves a step.
Sep 04, 2006 | Marantz SR8500 Receiver
Sony STR-DE845 Receiver Logo
181 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
