Question about Denon AVR-1600 Receiver
Denon Receiver AVR-1600
I am trying to find a good FM antenna for this unit. The one supplied with the unit only picks up a couple of stations. The community I live in does not allow outside antennas. I took the factory supplied wire antenna to Radio Shack but the sales guy said he had never seen one with that type fitting.
Does anyone know of a good affordable indoor antenna that will work with this unit?
Thanks,
Jim from South Carolina
  • Denon Master
  • 5,658 Answers
Seeing as you can't put an aerial outside, can you put one in the loft space, if you have one. You could use a standard FM aerial. It wouldn't be as good as mounting it outside, but it would give you better results then a wire.
Posted on Jun 21, 2017
SOURCE: reset channels??
http://www.eserviceinfo.com/download.php?fileid=26004
http://www.eserviceinfo.com/download.php?fileid=26005
Here are the links for the manual. I've lost my remote as well. I can't get my unit to recognize the digital audio input (optical). Very frusturating.
Posted on Nov 20, 2008
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: just picked up a Denon AVR-3801 receiver and
copy and paste this link in your address bar to view your manual:
www.manualnguide.com/.../manual.../denon-avr-3801-av-receiver-owners-manual.htm
Posted on Oct 01, 2009
Turk_97
  • 132 Answers
SOURCE: Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Posted on Oct 13, 2009
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
Why can't I get a tuner signal on my Denon Receiver?
make sure your antenna is hooked up properly, with even a bad antenna you should be able to pick up some stations
Mar 02, 2013 | Audio Players & Recorders
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
I HAVE BEEN TRYING TO CONNECT MY SPEAKERS AND I HAVE BUT THE TV IS NOT BEING PICKED UP BY THE RECEIVER. DENON AVR 1800.
Have you looked at the manuals for the Denon and the TV?
TV is a visual output, not an audio source, unless you tune stations through its antenna.
May 16, 2011 | Denon AVR-1800
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Can't find a radio frequency
check if the antenna is connected right. I assume it is FM. If AM and SW there are different antennas. Make sure the ends of the antenna connecting to the receiver unit is stripped. Best of luck
Jun 13, 2008 | Denon AVR-2500 Receiver
Tuner Woes
check your antenna connection in rear and try different location for your antenna----outdoor antenna is better.
May 24, 2008 | Denon AVR-1803 Receiver
Denon AVR-2400 Receiver
have you connected the antenna?since most receivers do not have an internal antenna an external one is provided.A LOOP ANTENNA(square plastic wires bound together) FOR AM and a LONG WIRE ANTENNA for FM.I hope this helps.
Mar 21, 2008 | Denon AVR-2400 Receiver
Denon AVR-1600 Receiver Logo
57 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
