Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I need new refrigerator door handles?
I need to know where to purchase new door handles for my refrigerator, mine were broken in a move?
  • 405 Answers
Go any appliance parts website and look up your model, you should be able to order them online
Posted on Dec 15, 2008
Rear door on 2001 sienna won't open
The door handle might be broken, you need a new part. I got mine online for $40. keywords: 2001 2002 2003 2004 2005 2006 2007 Toyota Sequoia Metal Lift Gate Exterior Door Handle for Rear Outside Van Tailgate Handle. You need to remove the back door panel to replace this.
Mar 06, 2010 | 2001 Toyota Sienna
The door handle on my sub zero 650 has come off.
On Few Models, To remove the existing handle have a look for clipped on covers hiding the screws.On others, With a small flat blade screw driver stick between the handle and the door trim on top and push it up and on the bottom push it down and you can access the screws in the handles and tighten.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 05, 2009 | Sub-Zero Bottom Freezer Refrigerator
Handle pin broke
this happened to mine while still under warranty, eventually the repair man brought a small replacement part which took 5 minutes to fix, but not before a previous engineer had ordered a complete new door. you should be able to get the part ordered, and it would be easy to replace yourself. Now my FP oven has broken down again
Aug 19, 2009 | Fisher and Paykel E522BRXFD Stainless...
Handle broken, need to replaces... Tried of dirty little hands in my ice..
your going to have to take the ice maker handle and disconnect it from the back of the maker then move it around and at the same time pull it towards the back until it comes out.
May 20, 2009 | Refrigerators
A broken handle on door&how to fix it
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
The door handle is loose and i cannot tight the screws i dont want to call a repair man why would they make it difficult to tight the door handle .it cannot be difficult something to make a dollar this is...
mine was the handle was loose on the door not the coil in the stainless problem . i will try and figure it out my self i will not pay to have the handle tighten
Apr 05, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Broken door handle
The fresh food door handle is part number is 218668401 and the freezer dor handel is part number is 218668401 same number. Visit my web page and enter your refrigerator model number WRS6R3EW1 or mthe door handel number
218668401 in the model or part search feature. Below is the like to my web page. (Click on link below)
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Mar 26, 2009 | Refrigerators
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Nov 07, 2008 | GE Refrigerators
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
