Question about Acer Aspire 3000 Notebook
Re boots itself
While turning on the laptop the computer runs through normal procedures, and then when all the booting is down it will shut down automatically and reboot itself. Please help. I am not very computer smart. Thank you
  • Chuck Markel Mar 25, 2007
    Now, how can I turn on virus software? I have a warning everytime the computer boots that my virus protection is turned off.
    President:
  • 2,961 Answers
When you turn on the pc keep pressing F8 and it will boot into safe mode. When in safe mode highlight the option 'Last Known Good Configuration' and press enter. The pc should now reboot normally, if not you will need your installation cd to do a system repair.
Posted on Mar 18, 2007
  • andrew pester
    andrew pester Mar 25, 2007
    This will be refering to your anti virus programme, assuming you have one which you should have, it may need to be enabled within the programme.
    If it is not refering to your anti virus programme you have installed, then there will be a anti virus menu within the bios settings, which should be disabled.
    Do a spyware scan as you could well have spyware which is throwing this false message up.
    If you have none download adaware personal for free use from here
    http://www.download.com/Ad-Aware-SE-Pers...
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
Dell laptop runs in safe mode only
Try a system restore - boot to safe mode and restore it to an earlier working state.
Jan 02, 2010 | Dell Computers & Internet
Laptop not working
try to boot the computer in safemode with networking .
first shut down the computer and then while u turn on the computer start pressing F8 on the computer for 12 times and it will give you an option for advanced boot option from the list select safe mode with networking and then try to boot the computer ,,,,,once u log on to safe mode then go to run and in run type in msconfig ,,,in system configuration box select services and disable unwanted services and then restart the computer on normal boot and then the system will work fine ,,,,,,
Jul 21, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
When i on the system, the fan is not rolling, sometime when on and boot upto the the window evironment, its shut itself down. what could be the possible problem with them
Please Check CPU making any noise or not.
remove the CPU side door and check Fan is rotating on Processor if not it may not rotate due to heavy dust inside. ( clean it and refix it)
Check SMPS Fan is rotating or not..
If fans or not rotating Heat Builds up then computer shuts down itself.
If both fans are working...Just Open BIOS window by press DEL button continuosly while startup and wait for 2 to 3 minutes If the computer shuts down Itself in BIOS Window also then we can confirm issue with Hardware.
If Computer not shutting down in BIOS Window then issue with Operating System Boot files corrupted.
While Turn ON the system press F8 to enter in Safe Mode.
Open command prompt by clicking on
Start >. RUN >> type cmd >> then press enter.
now type chkdsk /f
now press Y
then reboot PC it fixes the Boot files error then your PC works perfectly.
If you still exp same issue let meknow..
Feb 18, 2009 | HP Pavilion dv6000z Notebook
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Shuts off at boot up screen?
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Jun 24, 2008 | Acer Aspire 5000 Notebook
Laptop ?
First try to boot in the safe mode, by repeatedly pressing the F8 key. If it boots into the safe mode, press the start button, shut down then select restart. If it will not boot normally then, repeat booting in the safe mode and once booted go to programs/accessorys/system tools/restore the select a restore point date that the computer was functioning correctly and restore for that date. If it will not boot the safe mode restart the computer with the system cd disk and restore from it. BPCS
Dec 05, 2007 | Dell Inspiron 6400 Notebook
Power problems
There is most likely a software and/or driver confliction not allowing your system to shut down.  Have you recently installed new software or hardware?
Oct 18, 2007 | Dell Inspiron 6400 Notebook
Acer Aspire 3000 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
