Question about Radio Shack VGA PC Camera Webcam
Lip sync The audio is way ahead of the video; the higher I set the resolution, the worse the problem becomes. The camera appears to be REALLY slow. Is there an obvious fix, or is this just the nature of the beast? Any advice would be greatly appreciated.
  • jpdonovan Dec 28, 2008
    I'm running a Toshiba Satellite notebook with a 1.6 GHz Centrino Duo; 2 GHz of RAM; and XP Pro. Seems to me this ought to suffice. -- JD
  • 3,037 Answers
This is the way the webcam will be, a lower resolution will refresh the picture at a faster rate. What are the specs on your computer as they may also help the problem, but this is normal for web cams
Posted on Dec 15, 2008
  • Radio Shack Master
  • 19,396 Answers
That means that your computer does not have enough resources to manage the camera, let me know what CPU you use and how much RAM is installed on your computer, you may need an upgrade.
  • Ginko
    Ginko Dec 28, 2008
    2 GB Ram is enough to manage this camera, however , try lowering down camera resolution settings, if this sort out the problem, then you either need to add more resources, or to reinstall Windows to fix the problem.
Lip sync problems
that is a network problem nothing consumer can do about it .
Sep 29, 2015 | Televison & Video
VIZIO E470VA LCD HDTV audio and video are not in sync
Go to your On-screen Menu, go to settings, select audio, then select LIP SYNC. You can then adjust the amount of shift to synchronize the pix and the audio.
Sep 07, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
My VSX 517 amp's sound is outputted before the vision on the TV. The sound seems to be anything up to half a second ahead, it is not always out it depends on how long someone is speaking for, plus which...
Lip Sync issues are the nature of the beast. The TV has to process the digital video bitstream a lot more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. You didn't name yours so one does not know. I don't think this unit has that function. Look in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-517-S-Receivers-manual/id/2526bh740/t/2/
Apr 05, 2011 | Pioneer Audio Players & Recorders
Took video and put on pc. The words are ahead of video
Lip sync problems, I've heard that the best way around that is to keep your clips to less than 15 minutes.
I avoid the issue entirely by copying to a DVD recorder with a hard disk drive, edit on the recorder then right to DVD.
The downside to all this is its more difficult to add backing music etc.
Mar 30, 2010 | Cameras
Synchmaster 913 The unit displays 'Not Optimum Mode 1280 x 1024 60hz' after being run to approx 1 hour
Hello. That message appears when the video signal from the computer exceeds the monitor's ability to display it. If the sync is set too high(i.e. max sync on the monitor is 60 Hertz at that resolution), you will get that message. Check the video settings in control panel--("appearance and themes" in XP), go to the "advanced" tab and look at the refresh rate. Most computer video cards are able to far exceed a monitor's display ability. Don't exceed 60 Hertz--check the users guide for specs--the lower resolutions can have higher refresh rates(useful in games) Sometimes, a little lower video quality can yield a big performance difference in the display because the screen can update itself faster. (I use a radio control flight simulator pgm that is heavy on video ability).---Hope I was of assistance!---Rick
Sep 22, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
Cant get utube to publish my tenminmixes in full
Youtube imposes a maximum limit of 10 minutes duration for each video and 100 MB max file size. Since your vids are under the 10 min limit, you should look at the file size as the offending party. If it is over 100 MB, thats the problem. To reduce the file size you need to understand what a CODEC(COder-DECoder) is and how CODECs can be used to make video files smaller for uploading to Youtube. The file you want to up-load has two parts, audio and video, Each part uses a different type of codec to encode and save the "movie" you created with your video editing program. The most common and efficient video/audio codecs used on Youtube are MPEG-4 and MP3. If your video app is not set to encode audio to MP3, you are probably encoding the audio into a raw uncompressed WAV format (pronounced wave). Uncompressed WAV files are very large compared to the MP3 format. Setting the audio bitrate can be confusing. To keep it as simple as possible, I suggest setting the Bitrate to 128 kb/s STEREO if the video has music or 96 kb/s MONO if it is just people talking. Set the Sampling rate to 44100 Hz (or 44.1Khz) AAC is another Audio format. The same sampling and bitrates apply. The next thing you want to look at is the Video resolution and type of file you are saving/recording to. Since you are recording from a webcam, you may be using a propriatary codec that came with the camera. If this is the case, then you need to let me know what brand camera and software you are using. Most video cameras, including web-cams, use non-proprietary formats that can generate very large (but high resolution) files. For example: .avi & .mpg. You want to record at the highests resolution you can, BUT, you will save it later to a lower resolution compressed file. Many webcams can record at 800x600 and 640x480, but the file you will save for Youtube may be 320x240, 480x360 or 640x480. The higher the numbers the higher the resolution, but also the larger the file size. Also, the more motion there is in a video, the larger the file will be. So, if you have a lot of action and need to "squeeze" it in (compress) the video, use a lower output resolution (320x240). If it is an interview type video, where the background stays the same, you may get away with a higher resolution (640x480) if you want a sharper image. When recordings from the camera are saved as .avi, .mov or .mpg, you will have to change the output format in your video editing program to mp4 (H.264) format. You may also be able to set your webcam to record directly to the mp4 format, which would be ideal, if you do not plan on editing your video. Then you can simply record and upload. The bottom line. ------------------ When you are done editing your movie and are ready to save it. Find where you can set or change output options in the editing app. Set the audio and video bitrates and resolution to those best suited to your needs. Change the output type to MP4, aka H.264 (for video) and MP3 or AAC (for audio). Click save, wait a bit, upload your video to YT for the world to see and revel in the glory of being a producer. Scorpio
May 09, 2009 | YouTube Videos
Cannot set resolution 1640x1050
To answer your question in short: If your video card and monitor drivers are installed correctly and you are able to adjust the resolution to 1640x1050 in your settings then your card and monitor are able to handle that resolution.
Remember that at higher resolutions your display card performance might become very slow.]
This is due to your BIOS shared memory being only 64Mb.
To get better performance you will have to upgrade your display card to one with more memory. ie. 256Mb. or more.
Best of luck.
Regards,
Graemevm
Apr 22, 2009 | Biostar P4M80-M7 Motherboard
Screen resolution
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work. Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
D. AIM (AOL) Messenger
  1. On the VIM sign-in window click on Edit.
  2. Then click on Settings Enhanced IM.
  3. Next click on Enhanced IM.
  4. Then click on Audio Video.
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone Speaker
Camera The audio and camera should function now.
Additional information to use with VIM settings,
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Mar 12, 2009 | Microsoft LifeCam VX-1000 Webcam
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Radio Shack VGA PC Camera Webcam Logo
16 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
