Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
I plug in my kerosene heater, but it will not fire off
It has plenty of fresh kerosene
Pull the ignition transformer out and see if its burnt or cracked. Its below the filter housing. Thats what went wrong with mine
Posted on Jan 15, 2009
Tip
Kerosene Space Heater Tip
I have repaired many kerosene space heaters in the past. The number one problem that I see is everyone expects the heater to just come on every winter when they plug it up. But usually it does not. It's been sitting in storage collecting dust. And then you hear them say "It worked fine last year". If everyone would just do this at the end of each winter and you are ready to store your heater, (Drain the fuel & clean your tank out). Check your filters and replace if needed. It is that simple. When you need it, do not put the same fuel that you have in a can or barrel (from last year) in the heater. Discard the old fuel properly & just purchase some fresh fuel and start off fresh. If you use the old fuel that was left in the heater or can/barrel, you are just looking for trouble. If you fire the heater off with the old fuel, you are just filling the heater with problems. Water is the problem. The fuel tanks/cans, ect. sweat during the hot months and it all settles in the bottom. Inspect your fuel before using it. Look for water/trash that has settled in the bottom. Discard as needed. You will be nice and warm instead of having heater problems when your freezing & needing heat. Just remember "start off fresh".
on Dec 04, 2010 | Heating & Cooling
I have a profitter 210,00 btu fires but wont light what should the pressure gage read?
I'm guessing this is a kerosene forced air heater. the pressure for a 210k pro fitter is 8.5 psi.
Jan 13, 2012 | Heating & Cooling
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
60000 heater kerosene fires up but shuts off shortly after
Check the entire fuel like to the tank. They tend to break, plug up, etc. which causes a lot of problems. The strainer in the bottom also plugs up. Rick
Apr 08, 2009 | Reddy Heater 60,000 BTU Kerosene...
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
289 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
