Question about Apple iMac 24" Desktop
I have an Imac 24" 2.8 ghz. I run windows xp sp3.0 on it.
When I am in the pc mode and I open Pal Talk to have a discussion with some friends, the isight works (but a bit dark) but the voice communications does not work - my speech come out low and grabled. Is there something that I can do to correct this so that I can use my internal mike???
Thanks
nashgrandpa
  • 1 more comment
  • nashgrandpa Dec 17, 2008
    Hi Sean - your right this is my first time owning a mac computer.  I am using XP home edition service pack 3, and prior to installing it I did upgrade bootcamp  to 2.1 as you asked.  I have to agree that it is a hardware issue but as you probably know the Imac does not let you in or change the sound settings or the isight internal cam - or at least I don't know how to change them.
    That is where I am at now.  Thank you for returning my e-mail I appreciate it.
  • nashgrandpa Dec 22, 2008
    Sean - Sorry that it has taken me a few days to reply - I have to travel for a living.  I clicked the gray speaker icon and opened up the mixer controls.  When I look at Mic - at the top of the vertical slide bar - it is NOT highlighted - it is a ghost.  I am able to work with all the other bars as you described, however after selecting different hardware (of which there are only 2 that will allow me to enable the settings - neither of them of which allow me to use the internal mic or to use an external mic on Paltalk.  I can hear every well but my mic output is garbled and a very very low volume.
    Bill
  • Sean Cole
    Sean Cole May 11, 2010
    Hi Nashgrandpa,
    I don't use Pal Talk but I am guessing this is a hardware issue anyway. So you're using XP in bootcamp rather than Parallels and the internal mic comes out weird. Are you using the latest 2.1 drivers? These sorted out a heap of hardware issues. You can get it from here. Try that first and we'll take it from there...
    All the best
    Sean
    PiDigital
    Sergeant:
  • Apple Expert
  • 250 Answers
Hi again. Sorry it's been a while for me to get back to you. Work!
In windows, on the bottom right there is a red speaker icon. Double click it. In the window that appears click the tab labeled 'Mixer' There you can choose the input source - Line, Mic, etc - Choose Mic by clicking the little dot to the bottom right of the fader. Now set the input volume of the mic to about 1 (if the scale was 1 to 10). That should be about right but you can leave it up and adjust to suit.
The video settings you can only adjust using whatever software is using it.
There's loads more you can do with your audio from that mixer controller. I'd recommend just playing with it to find out what you can do. Have a play, you're not gonna do any permanent damage.
All the best
Sean
Posted on Dec 18, 2008
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
Jan 06, 2016 | Tablets & eReaders
Will not run in PC mode
Turn off the mains power for 15mins, then turn on the mains power and boot up your computer.
Mar 30, 2013 | Vizio All-In-One CA24-A1 - Core i5 3210M...
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
Why the system automatically go to safe mode
If you are using Windows XP then you may have the /safeboot set in the boot.ini file which will force XP to always boot into Safe Mode.
When the system has started, click on Start then Run and type MSCONFIG as the command to run.
Open the Boot.ini page tab and make sure that the /SAFEBOOT option is not selected in the Boot options section of the page.
Save the change and restart Windows and it should start normally.
Dec 27, 2011 | Dell OptiPlex 780 Desktop Computer 1 x...
How to install additional memory on my 24" iMac.
maybe this will help.
http://www.youtube.com/watch?v=bZLewEVOuTw
Apr 18, 2010 | Apple 24" iMac Desktop
Need assistance transferring video to imac
The Panasonic PV-GS12 will transfer video in video record mode and video playback mode using the DV connection (IEEE) Firewire port. PC Mode is restricted to memory card access via USB. If after connecting it in this manner if it does not work try this. With everything connected via firewire and iMovie running. switch the camera to PC mode and the import window should pop up. You may get a comunications error and if you do then switch to playback mode. The import window should stay open and you can control your camera with the iMovie controls.
Jun 01, 2009 | Computers & Internet
Cannot download video, only Card pictures
I do not know MACs, but a standard 4-pin to 6-pin firewire (IEEE1394) is needed. On Windows XP, plug it in, run Windows Movemaker and you are good to go. By the way, a "DV cable" is a firewire cable.
If your MAC cannot "see" your camcorder, try another firewire device to see if your MAC is the culprit, or drag your camcorder and firewire cable to a friend's PC running Windows XP and see if it works.
May 27, 2009 | Canon ZR70MC Mini DV Digital Camcorder
2.4 GHz iMac Intel Core 2 Duo DVDRW/CD-RW Desktop has Cd stuck
Hi, Sorry to hear you are having problems,
So, tell me is this a 17”, a 20” or a 24” iMac?
Have you ever opened or had this iMac opened by a technician ? If so, they may not have put it back together properly.
If not, this sounds like you might have to get in there and re-seat the optical drive.
are you handy and courageous or do you want to have someone else take care of it.
I should not be an expensive repair, no parts necessary, Apple service center should take care of this for about $150
Otherwise, take a look at this and maybe try it yourself:
http://www.kodawarisan.com/index.html
Now I know, it's a Korean website, in Korean, but the list on the right hand side, has the take apart information you need.
Good luck
Jan 10, 2009 | Apple 2.16GHz iMac Intel Core 2 Duo...
Windows xp opens and closes right away
Hi! i can understand your problem. It happened to me once. I tried to run the PC in the safe mode but on safe mode it doesn't run the antivirus program. If you have your harddisk of IDE type then connect your friend's hard disk in your PC as a Slave and Yours as a master.
You can do this from your bios setup.
Then Scan his hard disk by your antivirus software and remove all the virus from his Harddisk.
OR else you can reinstall his Windows.
Dec 27, 2008 | Microsoft Windows XP Home Edition
Imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Aug 05, 2008 | Apple iMac G5 Desktop
Apple iMac 24" Desktop Logo
114 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
