Question about Proscan 19LA25Q 19 in. LCD Television
I have a switch that if turned off it cuts power to certain areas
When this switch was turned off my tv was cut off
When I try to cut the TV back on the color would be green if it was on but it statys red and I cant get the tv to power back up
the DVD player and the satellite are working
Please help me I havent had this TV but 4 months
  • sam8827 Dec 15, 2008
    pleae let me know as soon as possible
  • cathyg49 Jan 02, 2009
    Power has shut off completely - won`t turn on at the top or with the remote. We replaced the batteries in the converter as we had been having trouble changing channels a few weeks ago. Now, nothing. TV is 18 months old!!! Help.
    Habit-Forming:
  • 82 Answers
Send the unit to manufacturer for replacement.
Posted on Feb 10, 2018
sewright34
  • 8 Answers
SOURCE: won't turn on
These units have a separate switching power supply that does indeed get very hot. What I have found is that a 1000mF@25v capacitor goes bad in the power supply and needs to be replaced. If your set's red power light turns green for just a second and then turns back to red without the set turning on, this may very well be your problem. You can either try to find another power supply (make sure it's rated at 12v-5amp) or take your old one to a repair shop. Be very careful if you decide to try a repair yourself, switching power supplies can pack quite a punch.
Posted on Jun 27, 2008
javswr
  • 44 Answers
SOURCE: DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Posted on Feb 28, 2009
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
  • 814 Answers
SOURCE: dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
Posted on May 21, 2009
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
I have a hyundai HPT 4280 tv that won't turn back on when the power has been cut. We had a power cut a week ago, and the tv still hasn't come back on yet, any suggestions?
hello my names amar
ive got a hyundia tv i need a power board htp 4280 do you know were i can get one please ive been looking all over
Nov 07, 2009 | Televison & Video
TV KEEPS CLICKING.ACTS LIKE CUTS ON AND OFF REPEATLY
Check for leaky capacitor in the switching relay area
Aug 17, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Power switch turns on and off
that would work if you want a costly bill. Try this before dishing out cash, the problem is the switch that tells the board to turn on and of is bad and a cheep quick fix is to open the back of your TV(#15) (unplugged of course)and remove the hex(#10) screws to the mother board look under TV tube and you will see the switch board,remove both hex screws(#10) and pull the switch board out,follow black cord to mother board and pull cord out of its port. know find the word KEY also #2 on the switch board, should be the red wire. cut this wire and be sure there isn't any bare wire showing at your cut, a piece of black tape will help this. reinstall the switch board and mother board and back of TV . you should be all good to go
Jun 26, 2009 | Televison & Video
During a power surge my tv turned off and it wont turn on now at all
i have a rca television and my t.v. just cut off when i was looking at it and , when i tried to cut it back on, there was no sound and no picture and the power button did not want to cut off on it's on i had to unplug it.
May 12, 2009 | Mitsubishi WS-55805 55" Rear Projection...
TV switches its self off when I turn on.
Protection circuits usually cut in when you have power supply issues and too much current. U might want to start checking out your power supply for bad components.
Apr 09, 2017 | Televison & Video
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
My tv
My tv will not turn on. We had been away for a week and no power interuption at home. We have unpluged the tv for short and long periods of time . We we attempt to turn the power on it cuts off by itself.
Mar 01, 2008 | Televison & Video
Proscan 19LA25Q 19 in. LCD Television Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
