Question about Vizio P42HD Television
Flicker on bright spots
My two year old Vizio P42 flickers, when warmed up on bright or highlighted spots. It looks like burst of lightning on spots like foreheads, cheeks, white hair, clouds in the background, lightsources - like lamps - against darker background. I sent a short piece of footage to Vizio. They are clueless and recommended to contact ITI for out of warranty service.
  • kjanson1 Jan 17, 2009
    Same for me
5 Suggested Answers
SOURCE: help - 15 mth old 42" edtv "plasma" black screen" have power and sound
I had the same problem....wasnt the main board but the two smaller boards...vizio changed them and no problem since .....
Posted on Feb 19, 2008
SOURCE: blotchy white areas with color around edges of area
wasd youre face and clean facial cleanser or cream
Posted on Mar 27, 2009
  • 50 Answers
SOURCE: Our 3 1/2 year old Vizio P42 plasma made a pop, screen now blank
Hello kilmertwo, my names Dave! What your TV did is called the POP OF Death! In order to repair the TV you will need to replace the Y sustain & the Z sustain board also! The loud POP noise you heard came from the Z sustain! If you take this TV to a local repair shop the cost of the repair is going to be around 800.00 big one! 450.00 parts and 350.00 labor! Not only will you be spending that amount but this is a common problem with this TV! So you take the chance of this happening again! What I'm trying to do is to save you from throwing good money after bad! Do not repair the TV! You can for the same amount of money buy a totally brand new TV! I would suggest that you buy a Panasonic! Trust me!
Please feel free to contact me if you have any questions! I'll be more then happy to answer any question you may have!
Dave
1-503-432-9904
Premium TV Tech
www.pleasefixitdave.com
Posted on Apr 01, 2010
  • 18 Answers
SOURCE: I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
Posted on Mar 01, 2011
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 26, 2013 | Electrical Supplies
Vizio P42 HDTV no picture
Try first unplugging power cable for thirty minutes, then plug back, this will drain power from TV completely and will reset it.
See if it works.
Oct 18, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Light flicker
The power supply to the lights may share a circuit with some appliance such as a microwave or refrigerator. The flicker is more noticeable at high brightness but probably occurs at lower brightness as well
Jun 11, 2013 | Kitchen Ranges
Vizio LED LCD picture flickers
Turn the backlight down all the way in the menu. Fixed mine after a year of banging on the back.
Jun 20, 2012 | Vizio E320vp 32 Lcd Black Led Hdtv, -...
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Projection television acting like an old picture tube TV.
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Sep 16, 2009 | Toshiba 43H72 43" Rear Projection...
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
yes you need to check the power supply board going to the pitcure tube board common problem bad transister
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42HD Television Logo
54 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
