Question about IOGear GCS632U 2-port KVM Switch
GCS632U - Speaker issues
After following the instructions in the manual to hook up the speakers, now when I play music on my main PC, I get feedback on the monitor (sqiggly lines keeping beat to the sound). No sound comes out of the laptop.
Originally didn't need sound so never hooked up the cable to KVM until a couple of weeks ago.
  • annaohoh Jan 20, 2009
    I took your advice and RMA'd the first GCS632U. I had my company purchase another one. Same problem! 8=(
    The laptop displays videos and plays music just fine. The desktop doesn't. Same squiggly lines across the screen. Updated the video driver, monitor driver, rebooted, switched KVM ports... all to no avail.
    Thanks for trying to help. I think after 3 hours of putzing with it today, I'm going KVM-less.
The only solution for great quality is to spend $150 more and purchase the higher end "Harmony" IO-Gear KVM switch, this works great! But if you don't want to spend that much, this is what I did with my IO-Gear GCS632U. I did RMA the first one and when the second worked the same way I realized I would have to live with it since I didn't have more to spend at the time! The video quality is terrible at high resolutions with this KVM, no MATTER WHAT!!! Playing with refresh rates helped a little, but I still saw some ghosting and interferance at times (most likely due to the lack of ferrite beads on the ends of the already "too small to carry a good signal" video cables), otherwise it looks and works great with resolutions under 1280x1024. The sound also suffers, obviously but I found out (using a multimeter) that the sound issue is due to the KVM unit trying to amplify the sound a little so to solve it I simply turned sound down in windows and increased the volume on my speakers until it sounded ok (if this doesn't work for you, try it vice versa).
Hope that helps!
Posted on May 14, 2009
    President:
  • 2,923 Answers
To isolate the problem, please follow the steps below:
1. Connect first your speakers directly to the computer to see if the speaker is working correctly.
2. Checked the physical connection: make sure that your speaker is properly connected to the KVM and the KVM to the computer.
3. Make sure that you are going to play a music on the focused computer.
4. Make sure that your speaker is supported by this KVM switch.
NOTE: The GCS632U is designed to work with 2-channeled speakers only. If you are using 5.1 multimedia speakers, there's a possibility that it might or it might not work. You may refer to IOGEAR Web site and you will find this information.
Posted on Apr 14, 2009
    Problem Solver:
  • 10 Answers
I think you have a defective device there. RMA!
Posted on Jan 10, 2009
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
Feedback through speaker during transmit
ARE YOU TALKING ABOUT THE INTERNAL SPEAKER IF SO THE WIRES TO THE SPEAKER INSIDE ARE BEING SHORTED TO GROUND TOUCHING SOMETHING METAL
Feb 24, 2013 | Radio Shack TRC-503 CB Radio
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
Speaker produces sound even when the zone is off
Since the Pyle speaker is a 4 ohm device, it's likely that when you have other zones on, the change in the impedance will affect the volume. Check to see what impedance your other speakers are (standard is usually 8 ohm), and if your tuner has impedance matching for your zones. If it does not, that's most likely your issue. You could get an impedance matching transformer at Radio Shack to resolve this issue. Please rate my solution, thanks.
Apr 17, 2009 | Pyle PWRC82 Main / Stereo Speaker
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
Music on phone through speaker when receiver is on the hook
You can press SPEAKER - 725 - SPEAKER from any phone to hear the music or cancel the music.
Oct 21, 2008 | NEC Dterm DTP 16D-1 Corded Phone
I have no instruction manual for my x-540 logitech speakers to set them up to play music from my Dell lap top
Hi bbphysio
I could not find any instruction manuals for you, but here is a great procedure on hooking up and testing your speaker system from Logitech. It is for the next model along from yours, but I am sure that it will help sort out you setup.
Thanks for using FixYa, a FixYa rating would be great for finding this for you. Cheers
regards
robotek
May 07, 2008 | Audio Players & Recorders
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
326 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
