Quit motor hums. released tensioner and motor wouldn't turn. removed the belt completely and motor will start and pump will pump. Is the motor bad or is there a slow start circuit in the timer?
  • marcstern730 Dec 16, 2008
    Thanks, WasherMD. Model # lw4202w. I've continued playing with it. I removed the belt and the motor hums but won't turn the pump unless I help it start turning. Once it starts turning I can tighten the tensioner and the belt will squeel but the drum will turn and the spin and drain will happens until the motor stops then it won't start up on it's own. It blows the overload. Is there a starter circuit on the motor or looped thru the timer? If not then I guess the motor is bad.
  • 113 Answers
Is this a top loader? Im guessing it is. Try to turn the basket by hand. Is it hard to turn. Sometimes a piece of clothing will get stuck between the inner and outer tub causing resistance. Do you have a model #? thanks dave, www.washermd.com
Posted on Dec 16, 2008
Electric dryer not heating. was a little and quit completely. Thermostats, thermal ?, and heating element ohm out good. Any ideas?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Dec 10, 2016 | Dryers
Drum does not spin. Belt appears to be ok
You have a bad tensioner or a bad motor. The tensioner for the belt can drag the motor. However, what you are describing sounds like the motor is shot. But make sure you are getting correct voltage to dryer and nothing is binding the motor.
Mar 03, 2015 | Maytag Dryers
Just put a timing belt and water pump on my 1995 dodge intrepid es 3.5 changed the tensioner pulley and new hydraulic tensioner, have had 4 new tensioners collapse can anyone tell me why they are doin
you have to release the tensioner as it is in neutral position what you need to do is push in on the tensioner and let go it should tighten the belyt as when you push it in past the lock you will see it come out quite a ways
Sep 18, 2014 | Dodge Intrepid Cars & Trucks
I replaced the water pump and belt on my Pontiac vibe and my car wouldn't start ? .... Finally got it started and now it is misfiring ? What did I do wrong
Did you not put the belt on correctly,should have
had instructions with complete kit,water pump,tensioners,
pulleys & belt
Aug 03, 2013 | Cars & Trucks
I need the timing marks for a Mazda 2.5 wl TDI motor as well as the technical specifications
TIMING BELT
Removal
Disconnect battery ground cable. Remove exhaust side spark plugs.
Remove fan shroud bolts and fan shroud, and position aside. Loosen, but do not remove, water pump pulley bolts. Remove accessory drive serpentine belt.
Remove fan and clutch assembly retaining screws. Remove fan and clutch assembly. Remove fan shroud. Remove water pump pulley.
On models with A/C, discharge A/C system using approved refrigerant recovery/recycling equipment. Remove A/C compressor from mounting bracket. Remove A/C compressor mounting bracket with power steering pump attached, and position aside.
Remove timing belt outer cover retaining bolt. Release 7 cover interlocking tabs. Remove timing belt cover.
Rotate crankshaft in normal direction of rotation so that No. 1 cylinder is at TDC of compression stroke. Align camshaft, crankshaft and oil pump timing marks. See Fig. 1 . Crankshaft keyway should be pointing straight up, and circle on crankshaft sprocket must align with notch in engine front cover.
Holding timing belt tensioner with Camshaft Belt Tension Adjuster (T74P-6254-A) or equivalent, loosen adjusting bolt and pivot bolt. Slowly release spring tension. Pry tensioner away from timing belt, and tighten bolt to hold tensioner in place. Remove timing belt.
Installation
Ensure crankshaft is set at TDC and camshaft sprocket timing mark and oil pump sprocket timing mark are aligned with inner cover timing marks.
Install timing belt on crankshaft sprocket, oil pump sprocket and then the camshaft sprocket. Loosen timing belt tensioner bolt.
Allow tensioner to adjust itself against timing belt. DO NOT tighten belt tensioner. Slowly rotate crankshaft clockwise 2 complete turns clockwise (as viewed from front of engine) so No. 1 cylinder is at TDC of compression stroke.
Recheck timing alignment marks. If timing marks are not aligned, reposition timing belt. Repeat timing belt tensioning procedure.
Tighten timing belt tensioner adjusting and pivot bolts to specification. See TORQUE SPECIFICATIONS . Install crankshaft pulley. Tighten center bolt to specification.
Install timing belt cover. Install exhaust side spark plugs. Install A/C compressor mounting bracket to engine. Install A/C compressor to mounting bracket. To complete installation, reverse removal procedure. Recharge A/C system, if necessary.
Oct 13, 2012 | Computers & Internet
Need to tighten the belt and nothing looks movable. Anyone have a diagram?
it the belt is loose, the tensioner is bad. Its a pulley that should move and has spring tension on it. its a large pulley about 3" in diameter. replace the belt and tensioner.
Dec 09, 2010 | 1995 Saturn Sl
Dyer motor in our LT7000XTHO quit - faint hum when start is activated. Does this motor have brushes or is there another problem?
you may have a bad bearing on the tumbler
dryer motors do not use brushes but you may have a bad start capacitor or start switch
If I were you I would check that the drum is turning free and the drive belt is complete and on place
Mar 09, 2010 | Dryers
Top loader Speed Queen takes long time to complete one wash.
sounds like your belt is worn or the tension spring too tight on belt the vee part of the belt should not be rubber it should look like a material type coating to let it slip until it gets up to full speed (It,s Meant to slip) If it,s worn the rubber in the belt will grip too much.Hope this helps.Cheers.
Aug 06, 2009 | Washing Machines
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
Clothes dryer
dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt. It will take care of your problem
When I try and start my ge dbb3300eaoww dryer it buzzes as if it wants to start if I spin it with my hand it will work. I put a new belt on it and it does the same thing.
Motor start switch is bad. This is typically replaceable with out replacing the motor.
Will take care of the problem.
My drum will sometimes stop turning in the middle of a cycle, and the motor just hums. I pause the dryer, open the door, rotate the drum, unplug and plug the electrical, and then it will usually complete the cycle. Does that mean the belt is "occasionally" slipping? How do I check this?
Replace the belt. It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time. This will take care of the problem.
Sep 15, 2007 | Dryers
Open Questions:
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
