How many watts you
need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will
help you determine proper wattage.
Instructions
Identify
the species of plants you have in your tank or that you plan to put in your
tank and how much light that species needs. Each species of plant will have an
optimal lighting requirements, from low light to bright light. To determine the
plant species, compare photos on the Aquarium Plants Photos and Profiles page
of the Aqua Hobby website, or take samples of the aquatic plants to your local
aquarium store for identification.
Write
down how much lighting each of the plant species in your tank needs. Give each
plant a rating of low, medium or bright. The books "The Complete
Fishkeeper" and "Freshwater Aquariums for Dummies," as well as
your local fish store, are good sources of information for this.
Review your
list and determine what type of plant dominates your tank. For example, if you
have mostly plants that need bright light, then use a bright-light formula. If
you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate
a range of watts of lighting you need for your tank with one of the following
formulas, depending on the amount of light you determined you needed for your
plants. For low light, multiply one and two by the number of gallons. For
medium light, multiply two and three by the number of gallons. For bright
light, calculate three and five by the number of gallons. For example, for a
20-gallon tank with plants that need medium light, you would get a range of 40
to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per
Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
There are some
limiting factors like the oxygen availability and the
filtration processing. I gave you some examples below they all refer for small
or large freshwater fish.
3 cm of adult fish length per 4 liters of water.1 cm
of adult fish length per 30 square centimeters of surface area. 1 inch of adult
fish length per US gallon of water. 1 inch of adult fish length per 12 square
inches of surface area.
If you own a
regular fish tank without any plants you only need enough light to be able to
see your fish clearly and conveniently. To get that result you'll need about
0.75 watt per gallon.
Live rocks
require one to two pounds per gallon, depending on the dimensions of the tank
and the density of the rock. I won't suggest you this system if you have a
heavily populated fish tank.
