Question about Electrolux Epic 6500 Vacuum
Powerhead no longer working
The vacumm works great except today when i was vacuuming the main powerhead shut off and isnt working anymore. I turn the switch on but only the light comes on. The bristles underneath are not working.
How can i fix this.? is there a belt or something that needs to be changed?
    Scholar:
  • 44 Answers
If you can hear the power nozzle motor running, but the belt doesn't spin, it is most likely the belt. You will have to get the belt from an Aerus dealer or a Vac shop. If you want to put the belt on yourself, you can. There or five or six screws on the bottom of the power nozzle that need to be removed and the cover should come off. Once the cover is off, you will see the belt and how to change it. Good Luck!!
Posted on Jan 01, 2009
Filter queen majestic power head not working, main vacuum working but no power in head when plugged in. any suggestions as to what may be the cause for this to happen.
Is there power at the head, have you checked with a volt meter, most likely if not then the cord to the head is defective.
Aug 31, 2016 | Filter Queen Vacuums
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
The powerhead on my Hoover Duros will not keep running. If I push the on/off switch it will come back on sometimes, other times when I push it it turns the whole thing off as its supposed to do.
I just had the same problem with my hoover duros, the vacuum was running fine but the powerhead kept going off. I would make a sweep with it and powerhead would be running and then next sweep powerhead would shut off. I had tried checking connection and belt, etc. I thought it was the powerhead. But then I found the problem. On the duros there are 2 pieces of wands that hook powerhead to hose on canister. They both connected and clicked in fine but I decided to check them separately. I hooked just one piece to hose and powerhead and then turned it on and then I did the other piece. ta-dah! that's what it was...it was only one section of the wand. When I hooked them up separately, one piece the powerhead worked totally fine and vacuumed like normal. When I removed that piece of wand and tried the second piece (actually the bottom section when both are hooked together) the powerhead did not work at all. So I just need to get a new section of wand. Hope this helps!
Nov 17, 2011 | Maytag Hoover Duros S3590 Vacuum...
I'm looking to buy the powerhead and hose for the fantom canister vacumm.
I have one for sale if you are still interested, and other parts for this vacuum. :)
Nov 01, 2010 | Fantom Vacums Lighting Canister Vacuum
I have a hoover celebrity QS wuith the power head. I have only used the powerhead for years purchased in 75) I removed the powerhead to use the brush and the power does not come on but if I put the...
You have done very well keeping this appliance working since 1975!!!
Lucky you!
I'm not certain you would be able to get replacement parts for this model any longer,
Maybe you will just have to continue with the powerhead only.
Nov 17, 2009 | Hoover Vacuums
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power nozzle don't work
I don't know which model you have or how old it is, but most models have a cord on the hose that plugs into a receptacle on the main machine. Sometimes they can look like they're plugged in when in fact they're just barely hanging there. You could also check the cord at the powerhead. Because the cord flexes with the motion of vacuuming, the cords can break inside. Wiggle the cord while the machine is running and if the cord is defective, the powerhead is start and stop. On some models, there is a switch on the hose handle to turn the nozzle off and on, and these are prone to failure. Also, there should be a reset on the top right hand side of the nozzle, but if this kicked out, it indicates a motor or electrical problem and should be addressed by a service person. If your powerhead has this reset, it's possible that the reset is sticking. Push it down a couple of times and see if that helps.
Jan 15, 2008 | Rainbow 75th Anniversary Canister Vacuum
My vacum power head wont work
fan belt might have snapped.  take off top by snapping out plastic over light.  good luck!
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
103 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
