Question about Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System
My cd player on the Sony HCD-G101 rotates the discs but ...
Won't play them. I just purchased it used and was told it does work and the lady even still had 3 CD's in it. Am I doing something wrong? Everything else seems to work fine.
Thanks in advance for your help
Brenda
  • 3 Answers
I had the same problem after i moved and everything ran but when i put in a cd the disc would spin for awhile then change to the next disc and just kept spinning and moving from one disc to the other none stop. so i opened mine up turns out during the move there is a small black plastic piece that sits on top of the laser in the middle it shifted during the move making it block the view of the disc. you will have to carefully remove the plastic piece from the top of the laser with out touching the laser lens and that fixed mine good as new. my problem is i need the remote code movers lost my remote and can't find the code to use the replacement i bought. Hope it helps if this is the same problem i had should work. i tried to move the black piece back into place but it just did not go back right to just removed it all together. they did not use anything to really hold it into place to avoid slipping.
Posted on Mar 16, 2009
Sony hcd wz8d
Power attnae hooked up on amp for sure
Feb 25, 2014 | Electronics - Others
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
I have a Sony CD/tape player model # HCD-NE3. When trying to read a CD - it says NO DISC. What should I do?
Typically a no disc display indicated dust on the optical unit ( lens ) or failure due to low laser beam emission. For the first case you have to remove the top cover and clean the lens very gently with a ear bud. The the cleaning does not solve your problem you have to replace the optical unit itself. Unless you have experience doing the above i won't recommend it. Replacement will cost you about 15$ plus labor.
Aug 11, 2011 | Sony Audio Players & Recorders
My husband had a Sony cd player that he used alot. He passed away 3 yrs. ago and I have not used it till now. I put a cd in and it will play for short while, then stops and the red light in front comes on....
Hello
Long duration of unused condition will make its laser head assembly to be infected by fungus. You haven't used this device since 3 years, and so the possibility is of 90%. If you have a lens cleaning disc, put it into it and play for three or four times. Sometimes this may help you. If not replace its Laser Pickup Unit, with same type and number. OK.
Mar 09, 2011 | Sony Audio Players & Recorders
`Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Nov 19, 2007 | Sony RCD-W10 2-Disc CD Recorder
Sony Player
THAT AINT THE PROBLEM
OLDER CD PLAYERS REQUIRE A SLOW BURNT DISC
SIMPLY BURN AT A SLOW SPEED
1 x , 2x, 4x. 6x. might work 1 X and 2 x WILL FOR SURE
Nov 18, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Sony system shows "initialising"
probably your laser is weak,if you're not qualified to open pls, visit nearest sony service center to have the laser replaced.
Jan 27, 2007 | Sony SCD-C333ES 5-Disc CD Changer
DVDs won't play
Hi Pookie, This is an easy fix. All you need to get is a CD/DVD-Player Laser-Lens Cleaner for about $5.00. You can get these at Best Buy, Circuit City, Radio Shack, or any similar place. Use this, and let me know how it works for you. Best regards, nightdiver
May 27, 2006 | Sony DAV-C450 System
Sony MHC-RV777D 220 Volt Hi-Fi Music System Shelf System Logo
278 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
