Question about Kenneth Cole KC3271 Wrist Watch
Battery replacement I can't seem to get the back off to replace the battery
  • 2,334 Answers
For that you need tool called watch caseback opener. It looks like knife, only the blade is very short, curved and hardened Plenty on ebay for around 5 GBP.
Ordinary knifes wont work as they aren't hard enough and you can damage the watch and injure yourself.
If you gonna try to use chisel and hammer action, then you will damage your watch definetely.
Why don't use watchmaker services? Battery replacements are not very costly.
Regards
Arthur
Posted on Dec 17, 2008
Replace batteries on spf-40 model 2273
Looking at pictures of the watch , you will need to remove one side of the strap by undoing the screws on the side of the strap.
once you have removed one side of the strap unscrew the four screws on the case back of the watch.
then you will be able to lift the case back of the watch , it has a rubber seal on it which you need to carefull not to break.
Good luck and be carefull.
Sep 19, 2017 | The Watches
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
Nov 01, 2014 | Timex Indiglo Watches
What's wrong with my watch?
New batterys can go bad, that is why they have a warranty. Replace the battery
May 16, 2014 | Timex Expedition Watches
F&S FE6B-1 battery replacement
It will either unscrew if evenly spaced notches exist around the cap's edge if threaded or snap off if a small cavity exists beneath the cap's edge to insert a jeweler's screwdriver.
Dec 22, 2013 | Field and Stream Watches
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
The back doesn't seem to want to snap back in
Try a very small dab of a very light lubrican on the sealing edges.
If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
Season with a lot of parience... good luck!
Apr 19, 2010 | Timex 27191 Wristwatch
I can't find a replacement battery, I have 2 3
Go to "http://relicbrand.com/pdf/Service_Form.pdf" and you will find an order form with prices for repairs and battery replacement.
It may seem expensive for a replacement battery but if you see the number of people who can't get their watches to go after battery replacement, you wouldn't hesitate to send them off.
Mar 17, 2010 | Relic 0504648FA
Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Feb 26, 2010 | Swiss Army Wenger Commando 70728 Wrist...
How do you open the back of a raymond weil men's
I suggest you take it to a watch shop. DIY battery replacement is not as easy as it seems.
Frequently there are cries for help after a battery has been replaced and the watch no longer works!
Feb 10, 2010 | Raymond Weil Parsifal W1 watch
Kenneth Cole KC3271 Wrist Watch Logo
234 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
