just got an infinity PERFECT 12.1 sub and i have and mtx rt2200 amp. When ever I start to turn the gain up on the amp, the sub goes nuts, it hits random notes really loudly and doesn't go with the music. Is the amp broken or is it just a wiring problem?
Set the amps pre-amp input to match the output of your head units pre-amp output voltage.That should give the best clarity,If not, then you have a problem elsewhere.
Was this solution helpful? Show your Appreciation by rating it:
I have the bose 901 and the bose am5 acustamass speakers systems. Whenever the system is in the surrond mode, I get a lot of cracking and popping out of the speakers, especially when I am watching a show with a lot of action such as bombs exploding and guns being fired. What could possibly be the problem.
Show your appreciation by commenting on just got an infinity PERFECT 12.1 sub and i have and mtx rt2200 amp. When ever I start to turn the ....:
Solution #4
posted on Jul 11, 2007
Guest
Rank: Apprentice Rating: 0%, 0 votes
Using a high quality anolog multimeter (Simpson 260 series)or a digital meter set it up for measuring D.C. voltage. Set the range (if not automatic) for 50 volts or so - depending on the meter. With the amp on and acting "nuts" put the test leads from the meter on to the speaker terminals - If you see a fluctulating D.C. voltage more than likely one or more output transistors is shorted out. Take it to a repair shop or better yet e-mail the manufacture and see what they can do for you.57GEARHEAD
Solution #5
posted on Aug 08, 2005
Perkins - usenet poster
I wish I knew what the problem was that you are experiencing. The only advice I have for you is to maybe try posting in the Car Sound & Performance Forum as they are much more active. You will have a better chance of getting a helpful reply
