Question about Uniden Cordless Phone
Brand new remote set can't be registered
Brand new:27909 works great.the brand new remote 27911 can't be registered to the 27909.my nickname is betty hewitt,password is 86a2a in addition i can,t get the back off of the remote set to access the battery compartment.If i were to try to use any more force i could scratch or mar the remote set and i could not return it.
I can't get into the icq chatroom. it needs my register. How can I do the register? Where I do the register? Please kindly advise. Thanks, Judy
You'll have to register your name to a mod on ICQ.
1. Contact !ChanServ through a PM.
2. Type /join #ophelp to !ChanServ
3. You will receive a PM from WatchDog explaining how to register on ICQ:
<Watchdog> Greetings, due to the recent changes, kindly make sure you have a Registered nickname by Typing
<Watchdog> /msg nickserv Register Password Email
<Watchdog> An Authentication email will be sent to your entered email, authenticate your registration with the code that will be sent to you.
<Watchdog> Additional commands can be as following
<Watchdog> /msg nickserv identify Password (to identify as the owner of the nickname each time you login)
<Watchdog> /msg nickserv set hidemail on (to prevent users from finding your email through nickserv's info)
<Watchdog> /msg nickserv set enforce on (to prevent anyone else from using your nickname unless they identify with the correct password).
Hope this helps. :)
Jul 31, 2011 | ICQ Instant Messenger
Ge cordless phone 27909 will not register ive unplugged and re plugged the phone, ive confirmed that it is a working power and phone jack. iT KEEpS reading not registered
The registration instructions are in the fourth column of the manual at
http://www.home-electronics.net/ge/pc/IB/27909EE1_IB.pdf
Apr 25, 2011 | GE 27909 Cordless Phone
How do you enter console nickname
Hello
Access the Wii System Settings.
Choose "Console Nickname" on System Settings 1 to display a white rectangle with the current Nickname
Point at the text area (white rectangle) and press the A Button
Use the Wii Remote on the on screen keyboard for entering the new console Nickname.
Confirm the Nickname is correct by clicking the "confirm" button on the bottom right corner.
Dec 25, 2010 | Nintendo Wii Console
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
May 04, 2009 | Uniden Cordless Phone
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Mar 22, 2008 | Uniden Cordless Phone
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
