Question about Now Hear This SA-2 Amplifier
NHT SA-2 Amplifier Popping Noise
I have a NHT SA-2 amplifier hooked up to a NHT 10" subwoofer. Once the amp warms up I get loud popping noises coming from the subwoofer. Any advice is appreciated on what I need to do for trouble shooting this issue.
2 Suggested Answers
  • 56 Answers
SOURCE: I have a NHT SA-2
sounds like speaker is clipping (overdriving) put a meter onthe disconnected speaker and see what the resistance is,4 ohms ,8 ohms ,if the meter wont stay in one place (numbers changing constantly) you have a burnt or damaged coil in your sub, if that is not the problem change your RCA's cables to make sure it not a bad wire including speaker wires! GOOD LUCK
Posted on Jan 10, 2009
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
Gfa 545 output transistor replacement
first you break input signal from amplifier and boost up volume and see noise coming or not if not means u have preampfire section problem
May 17, 2012 | Adcom Audio Players & Recorders
My su-g95 technics Stereo integrated amplifier wont play any noise. and when i adjust the volume it makes a popping/crackling noise. i am 100% sure all the speakers were hooked up correctly.
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Sep 29, 2011 | Technics SUV500 2-Channel Amplifier
Popping noise from the subs
check rca wires you should spend good money on these it will help with road noise
Mar 25, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
PDX-1.600 no sound from speakers
check your coil wires on the back of the sub
Apr 11, 2009 | Alpine PDX-1.600 Car Audio Amplifier
I have a NHT SA-2 Amplifier 1996 model year. Once unit warms up I get load poping noises from the subwoofer. Please advise what may be causing this to happen.
Dec 15, 2008 | Now Hear This SA-2 Amplifier
Subwoofer thumping when turn on
Your subwoofer is not getting enough power, or it is grounding out due to a bad connection. What is powering the subwoofer? You might want to consider buying an AC to DC power inverter and a car amplifier to power your subwoofer. You connect the AC/DC inverter to your amp the same way you would in your car (+) to (+) and (-) to (-). The only other thing you will have to do is run the remote wire to the (+) on the amp. You can buy the AC/DC inverter at radioshack for $49.99, and all you really would need is a 200watt max amplifier and that would cost you about $10-$20.00 for a cheap one.
Feb 24, 2008 | Audio Players & Recorders
Now Hear This SA-2 Amplifier Logo
628 people viewed this question
Top Now Hear This Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Now Hear This Audio Player and Recorder Expert? Answer questions, earn points and help others
