Question about Sharp AR-160 Copier
The start button won't turn green when power turned on.
Our Sharp AR 160 won't copy. The start button won't light up. Help!
  • 1 more comment
  • knelson302 Dec 16, 2008
    When the power is on, the lights work on the panel to select original paper size, reduce/enlarge, and the output paper location. BUT, the start button needs to be on/green, and to start the copier's operation.
    No error message is communicated on the panel. Thanks for any ideas. It was purchased 8-9 years ago, so I hesitate to put any money into having it repaired.
    Karen
  • Roger Binsfeld May 11, 2010
    does the machine just keep running & running or is there a cade in the window? if it keeps running you need to add toner.
  • Everett Lin May 11, 2010
    have any error code?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
If the machine needs toner you will be able to change paper size & reduction but the machine will not come to ready[green ready light lit]. so if the machine keeps running after you turn it on it needs toner. if you leave it on for lets say 15 min. does it give you an add toner light or an error code?
Posted on Dec 16, 2008
  • 29 Answers
I think the problem is on the led light that is the reason why the star botton not in on ready mode/green.my be theirs is a lost contact in the panel board.if the toner in indicator are not in red blinking.
Posted on Dec 17, 2008
How to clear F5 error in Sharp AR-5316E, my technician have already cleaned the glass and all the optics in the scanner including the lamp and the white strips on bottom but still the error remains.
F5 errorContent Copy lamp error
Detail Copy lamp voltage detection error
Cause Power unit trouble, Copy lamp trouble
Inverter trouble, MCU PWB trouble
Check and remedy
Replace the power unit.Check the copy lamp ON with SIM
5-3.
Replace the copy lamp.
Replace the inverter.
Replace the MCU PWB.
Aug 31, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Sep 17, 2008 | Sharp Office Equipment & Supplies
Reset counter sharp ar-5631
what counter you like to reset ,we have error counter .jam counter,paper feed counter ,spf counter,drum counter
Nov 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-160 has an error code CH when you power it on
Actually that means your out of ink. Odd code, but that is what is means.
Jan 29, 2009 | Sharp AR-160 Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-156 will not copy
Usually that means the polygon motor isn't up to speed.
Try turning the copier off, wait 20 seconds, and turn the power back on.
Is there any other devices plugged into this electrical outlet?
Oct 27, 2008 | Sharp AR-156 Copier
Sharp AL 1644
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Sep 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
Remove error in AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-160 Copier Logo
119 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
