Question about Sony KP-53HS10 TV
Black screen, small portion of top of picture in view at bottom of screen
I purchased a used Sony KP-53HS10, rear projection TV from a friend. It's about six years old and worked fine for three weeks, after I moved it the hour drive to my house. Suddenly we turned it on one day and the only viewable portion of the picture was the top-fifth of the picture, seen at the very bottom of the screen, with the red, blue and green lines surrounding the top of this "picture". The rest of the screen is black. One day the entire picture appeared for a few minutes and then the above situation returned again. Since then (a week) there has been no change. "Flash focus" does not help and the viewable portion of the picture does not include the on-screen menu, so I can't see what I'm doing with that and have resisted "flying blind", so far. Sound is fine and the problem exists when using DVDs and VCR, so it's not a signal problem. It is connected through a cable box.
  • Mike Mullins Apr 02, 2007
    Thanks, I have a tech coming out Thursday. We'll see what's up, then...
    Genius:
  • 1,074 Answers
Your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Posted on Apr 02, 2007
I have a Sony projection TV KP-53HS10. From one
It is most likely the convergence board. Rear projection TVs use three lights to display the image. The image is aligned via the convergence circuit. After many many hours of use the capacitors and resistors on the board lose their tolerances. It is very expensive to repair if you take into account the price for a new TV and the quality of the image you will be getting if you do have it repaired.
Mar 01, 2011 | Sony KP-53HS10 TV
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
On My sony kp 53s75 tv the picture does not fill the whole screen on the HD channels
it is most likely normal--first generation HD sets were 4X3 which means picture is either small left and right or top and bottom; sets which have 16X9 offer full screen HD
Aug 07, 2009 | Sony KP-53S75 53" Rear Projection...
Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Jan 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10 - Green & pink halos & picture "bowed" on edges
you will need to replace the convergence IC's and test resistors on them for bad values , if you want to do the repair yourself
otherwise to have a tech come out and do the repair will be about $300
Dec 12, 2008 | Sony KP-53HS10 TV
Screen goes black and resets during HD shows
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Aug 31, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS10 TV Logo
161 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
