Question about Mitsubishi VS-50607 50" Rear Projection Television
Started out with an intermittent picture and sound. When the picture and sound went off I could still get the pip to work on the right side only. Next it turned off and wouldn't turn on. I found a blown 5 amp fuse next to where the power cord plugs in. When i replace it and plug it in it instantly blows the fuse.
You probably had a voltage surge. Most sets have a component called a varistor on the power supply board. If you pop off the back you should see this varistor near the fuse. I should look blown or brown or defective in some way. Varistors sense voltage spikes and fuse the positive and negative of the supply together to send the voltage spike back through the ground and save the rest of the electronics in the television, but this results in blowing the fuse instantly when you plug the set in. The varistor will most likely have a disc shape to it, and possibly a brown-orange color. Most of the time you can just cut out these components completely with a pair of wire cutters and the problem will be solved after you replace the fuse. Just make sure to plug the set in to a surge protector because the sensitive electronice inside the tv will no longer be protected from voltage spikes! Hope this helps!
Posted on Aug 08, 2007
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Posted on Mar 19, 2007
Dec 05, 2017 | Cars & Trucks
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
Feb 23, 2014 | Audio Players & Recorders
Oct 01, 2012 | Motorcycles
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
Jun 02, 2010 | RCA F36665 36" TV
Feb 23, 2010 | Powerline 0900-73 Slimline Inverter
Jul 07, 2008 | GE 35GT695 TV
Feb 28, 2008 | RCA F32672SB 32" TV
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
182 people viewed this question
