Question about Intel D865GBF Motherboard
Power supply My M/B has an ATX 4pin conection pluss a 24 pin conection do i connect yhem both to my M/B ?
  • 104 Answers
Yes you will only use 20 of those 24 pins on this motherboard.
Posted on Dec 15, 2008
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
Can you connect the 4pin power supply to the 8pin on board 12v
Yes, you can connect the 4 pin power supply to the 8 pin with little trouble but, you should not try any advanced features like overclocking or crossfire. If you would like to do those things I suggest getting a 4 to 8 pin adapter (very cheap usually less than $5) at most local computer stores.
Oct 10, 2010 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
System won't turn on but when i pushg down on one side of the power suply connectore the fan starts running but computer stioll won't turn on it used to boot up then opne day stopped
It sounds like you have a faulty connector - I would return the item under warranty. Otherwise, if it is out of warranty, you will have to source a new motherboard.
Nov 23, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
Verifying power connection 20/24 pin?
yes only 20pin but if you have a 20+4 pin its a ok to use just u need to cut or remove the 4pin..
May 23, 2009 | Acer Computers & Internet
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
I change the power supply but i have a little problem. The new one on the ATX power connector have only 19 pin then 20 old one plus extra 4 pin for something else. The new power supply in Rosewill...
The extra 4 pins on the power supply's atx connector is for new motherboards that require 24pin power supplies. If your motherboard has a 20pin port, then only connect the 20pin portion of your power supply connector.
If your power supply has a 24pin fixed connector that can't be split into a 20+4pin configuration, and your motherboard doesn't have space to let the extra 4pins on the side, then you might want to consider returning the power supply and change it for one that can be used as a 20 or 24pin. Otherwise you will need to cut the extra 4pins apart.
Jan 05, 2009 | ASUS P4B533 Motherboard
No display or POST
WAS THE POWER SUPPLY WORKING? IS THE 4PIN BLACK AND YELLOW CONNECTOR FROM POWER SUPPLY IN PLACE? DID YOU TRY BIOS CLEAR? IF IT IS NOT A NEW BOARD - CHECK FOR BLOWN CAPS AROUND CPU (UPRIGHT CYLINDER TYPE THINGIES. RESEAT RAM. CHECK IF MAYBE ONE OF 24 PIN ATX CONNECTOR DIDN'T PUSH OUT OF SLEEVE.
Nov 06, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Hercules switching power supply 500 wat max
yes 20 pin connecter power supply is ATX(advance technology extended )power supply and old which was low watt and 24 pin is EATX (enhaunced advance technology extended) power supply is new and high watt so 4 pin connecter can be detached from 24 pin connecter and can be fitted in 20 pin connecter
Oct 18, 2008 | Guillemot Hercules Dual Fan ATX 450W Max...
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Intel D865GBF Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
