No check engine light. no codes. starts and idles good. will not rev over 2000 rpm. .will not drive over 25 mph . replaced fuel pump and filter no difference.
Get someone to rev the car and see if the exhaust note sounds muffled!!! i.e blocked or bent if it sounds normal chech fuel pressure and more importantly fuel flow the guy with air flow meter was proberbly right
regards ray w QLD OZ
It could be that you have a bent valve or a blown head gasket, either way you ar elooking at some bucks to have it fixed
Hi there have you check the air flow system (pipes for blockages,pipes that may have split etc) sounds if it is air flow problem.
check your catalitic converter ill bet its plugged same thing happened to me
