Question about Kenmore 24032\24036 Top Load Washer
No spin or drain on Kenmore 25972
My Kenmore 25972 won't spin or drain; door switch assy. seems to have fallen off, and I can't find it. Possible to replace?
  • nandcharlan Dec 16, 2008
    Can't find any info on this model #; seems to be discontinued. Really rather not call a repairman - $$$ - any other options?
    Not your fault - I got the model # wrong. Sorry about that! It's really 110 92597200. All good now - the switch itself is okay - the actuator snapped off somehow. I just taped the switch lever in the 'closed' position (temporary fix), and now the washer's running fine. Replacement actuator is only about $14. Whew...
  • Kenmore Master
  • 5,569 Answers
Unless this is different from any washer we have ever owned, the door switch doesn't prevent or permit the pump from working but only the spin.
Go to the Sears website and follow links to the parts section. Enter your complete model number and there should be a detailed parts illustration that would allow you to learn where it is located.
Posted on Dec 15, 2008
  • Steve Allison
    Steve Allison Dec 16, 2008
    Sorry that didn't help.
    I did some further checking and got essentially zero reponse as if the model number didn't exist.
    I guess I am unable to help you.
  • Steve Allison
    Glad you found your trouble.
    For all of our different workhorses, I have found illustrations as often as possible and kept them local so I don't have to seek them out when I need them.
    Having them on hand is very helpful in diagnosing the kind of problem you just had.
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
How do you replace the lid switch on a Kenmore 70 series washing machine
Hi.
Check for drain blockage at the filter. Check setting of drain hose at the back. If there is no drain problem check pressure switch, central control unit and pump motor.
Here a tip talking about drain and spin problems: http://www.fixya.com/support/r7775926-no_spin_tip_all_washers
Nov 13, 2011 | Kenmore Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washer fills up agitates then when it should drain ,nothing.motor dosent come on to pump water out.
In most cases all brands will fill and agitate with the lid open, but will not drain or spin with the lid up.
It sounds to me like your lid switch is either bad or misaligned.
The first thing to check is the actuator plunger on the lid. Make sure it hasn't fallen or been broken off. Look for a piece hanging down from the lid that looks like a little finger that when the lid is closed, would hit and depress the lid switch ,which is under the top of the washer.
If it looks like the actuator is good shape then the lid switch is either bad or misaligned. Take a pencil or a bic pen and depress the lid switch. Making sure your washer is plugged in and in the spin mode. If it begins to rotate to spin and drain then see if a screw has fallen out that holds it in place or became loose not letting the actuator hit it correctly.
If the switch does not seem loose and it will not start the machine when depressed with a pencil it is probably time to change it out.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
Won't spin
I replaced the door switch/latch assembly. It works!
Sep 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore washer 110 20912 990 will not spin or empty
sounds like perhaps you dissconnected the door latch assy,and never reconnected??? hte unit will not spin/drain with the door latch not making contact
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine will not drain water.
you did remove the cabinet to replace the lid switch correct?, try removing it again and unclip the pump assy dont remove the hoses, just unclip form motor assy and hold out of the way, try putting unit into a spin cycle now.. is it spinning ?? or at least he motor spinning??? this is a direct drive unit so as long as he motor spins the pump also spins, with exception of a bad pump , something clogged inside the pump, or an obstruction in the drain line itself.. if the motor not turning at this point id have to believe that switch isn't making contact( but is new and it sure should be)timers not sending down power (doubtfull).alll seems pretty doubtful less the bad switch( remember that with the cabinet removed youll need to TEMPORALLY jump out the lid switch,
Mar 25, 2008 | Washing Machines
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 24032\24036 Top Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
