Question about HP PSC 1315 All-In-One InkJet Printer
Hp psc 1410 cannot delete remote redirected print job
Hi. I am running xp pro and like my psc 1410 all in one. In the past for local blocked jobs restarting the pc and printer would do it. This time nothing seems to work. I have restarted the pc several times. Stopped and restarted the spoolsv service. The job is still there and shows "deleting", but never goes away. I have tried removing and reinstalling the printer but even that wont work while that job is sitting there. I am pretty stuck, any help would be appreciated jmpaq
    Problem Solver:
  • 35 Answers
There is a option in printer box "Purge Print document" you try that option, After Purge then delete the document, which is still present in your box. At a time turn off the printer. All the pending printing commands will delete.
Posted on Sep 24, 2007
SOURCE:
Not printing after paper jam
Try the HP website. I just downloaded a tool that fixed my problem which was with a 1410 that worked with a Mac and with XP, but not Vista (although it had in the past). Print jobs showed in the queue, there was no error msg, but wouldn't print, either.
Oct 21, 2011 | HP PSC 1410 All-In-One InkJet Printer
Print job cancel wont work
Hi, if the print job doesn't get deleted after a restart of your computer, do the following:
Click on start -> Run, then enter: services.msc Click OK to open the Services windows. Locate the entry "Print Spooler" in the Services list. Click it and choose "Stop" and "Restart". Your print job should then be deleted.
If my answer was helpful to you, please leave a positive feedback.
Jul 18, 2010 | HP PSC 1350 All-In-One Thermal Printer
Printer troubleshoot
try to cancel all the print jobs ....
you will see a small printer icon in the start taskbar
somewhat near the clock ....
double click it...
cancel all the print jobs...
switch off the printer and then switch on the printer again
Dec 22, 2009 | HP PSC 1410 All-In-One InkJet Printer
I cannot delete a document from the print que. It won't print and it won't delete and the printer won't print anything else until one or the other has been done. Running XP, printer is and HP PSC 1410 ....
hmm..unplug the printer from computer and power printer down. that should clear the printer memory. then plug back into computer, before turning printer power back on. see how that helps.
Nov 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
I cancelled a print an hour ago and it is still deleting
go to the computer and click on start>>control panel>>administrative tools>>services.
select print spool and right click to stop it.
now opne the printers and Faxes. open the printer properties and delete all of the print jobs.
go back to the service and restart the print spool, and turn on the printer.
Jun 07, 2009 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1410 All-In-One printer speed is slow
Hello Sir,
I would like to provide you few workaround steps, you may try to improve the printing speed on the computer.
Delete all the Temporary files:
For Windows XP:
(1) Click Start >> In the Run window, type "%temp%" which opens temporary files folder.
(2) Delete all the files that are listed over there.
If Windows Vista:
(1) Click Start >> Programs >> Accessories >> In the Run window, type "%temp%" and press enter.
(2) Delete all the files listed under temporary files folder.
Another Workaround:
(1) Click Start >> Printer and Faxes.
(2) Right click on the Printer icon which is set as default and select properties.
(3) Click on Advance Tab.
(4) put a check mark on "Print Directly to printer" option.
(5) Click Apply and Ok.
Hope this solution would be helpful in resolving the issue that you are experiencing.
With Regards,
Ashesburn..
Feb 24, 2008 | HP PSC 1410 All-In-One InkJet Printer
Can not delete last file in print queue.
Found On: http://www.nztechie.com/can-not-delete-failed-print-jobs-in-windows-vistaxp2000/270/ Can not delete failed print jobs in Windows Vista/XP/2000 Occassionally, a job will stall in the Printer Spooler. The jobs status will constantly be reported as “Deleting”, but the job will not disapear. ‘Cancel’ and ‘Restart’ have no affect.
Resolution: Stop the Print spooler, manually remove the stalled jobs and then restart the Print Spooler service.
Method 1:
1. Press Start-> Run -> Type ‘Services.msc” -> Press Enter
2. Scroll Down the List until you find “Print Spooler”
3. Highlight this name
4. Select “Stop the service” from the left pane
5. Minimize the Services window
5. Navigate to the following directory in Windows Explorer
“x:WindowsSystem32spoolPRINTERS” where “X” is the drive you have Windows XP installed.
6. Delete the contents of the “PRINTERS” folder. Do no delete the “PRINTERS” folder iself.
7. Maximize the Services window
8. Scroll Down the List until you find “Print Spooler”
9. Highlight this name
10. Select “Start the service” from the left pane
Your issue should be resolved.
Feb 13, 2008 | HP PSC 1410 All-In-One InkJet Printer
Jobs stuck in the print queue for hp 2410xi all-in-one
just go to run and type services.msc and press enter it go to services option select print spooler and stop it and then run it will remove all the pending job and ready for print new job.
let me know if you stuck anywhere bye.
Dec 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
248 people viewed this question
Clive
Clive
Thomas F. Schneider
