Question about Dell E196FP 19" LCD Monitor
Lcd monitor my monitor (19 in. lcd) suddenly shows hundreds of vertical colored lines and shows no signal. buttons on front of monitor don't work (except power button works)I attached to a laptop (different computer) and monitor responds to F8 toggle, but same problem with lines. tried to follow Dell troubleshooting but requires ability to see an image on screen. am I cooked?
  • Allan Hoffmann Mar 18, 2007
    Thanks tomj23. it has the same problem with a second computer. I'll call Dell.
This happened because you set your subwoofer up to close to your monitor, same thing happend to me. you should have your subwoofer about 2 feet away from the monitor. this problem can be fixed at local computer shops , i just got mine replaced for free though.
Posted on Oct 24, 2007
  • 624 Answers
Hobo, The chances are good that it?s the monitor; however, there are a few things you can check: -Try connecting the monitor to another computer, if the problem follows. If it doesn?t try the rest of these suggestions, if not skip to the bottom. -Remove the VGA connector from your PC and inspect the pins to make sure none are bent over or corroded. -Try replacing the VGA cord that connects the LCD with the computer. -Try opening your PC, removing and reinstalling the video card assuming it isn?t built into the motherboard. This monitor has a three year warranty from Dell so I wouldn?t try opening the monitor case until you call them. Even if you suspect it is call them up anyway, on more than one occasion I?ve called Dell about a problem with an out of warranty PC only to find out there was a unadvertised replacement program. So call it can?t hurt. If its out of warranty then depending on your comfort level you can either try to fix it or take it to the local repair shop. Usually they will do an eval for about $35. Let us know if you have any other questions and please don?t forget to rate this posting.
Posted on Mar 18, 2007
Describe your vs19 (Silver) 19"
You did all the correct diagnostics and proved that the monitor is faulty. Take to a local service centre for repair.
Feb 22, 2018 | HP vs19 (Silver) 19" LCD Monitor
Powers on but only get vertical colored lines
Try to replace all of failure capacitor on power inverter board.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 27, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
There are two vertical lines on my lg flatron w1942s monitor one is red and other is green line
Go to the buttons on the bottom of your monitor it will give you an option to change the vertical and horizontal setting.
Mar 12, 2011 | LG W1942S 19" LCD Monitor
HP L1906 19-inch color LCD Color Monitor ..suddenly stopped working (not even "no signal" message. What can I do please ? malcolm watson
First check all wires and connectors are tight and in their respective place.Then check supply to your cpu
OR
REMOVE YOUR POWER CORD AND HOLD THE ON BUTTON FOR LIKE 30second TO A MINUTE AND THEN CONNECT IT BACK AND TURN IT ON
Thank you for using fixya
Jan 06, 2011 | HP Hewlett Packard L1950g 19 inch LCD...
Lto much colors vertical lines
hi
if your getting vertical lines in you screen it means you have problem with screen you have to go to services center
this is display issue
Oct 12, 2010 | Acer AL1912 19" LCD Monitor
My Samsung SyncMaster 910MP has thin colored lines all over the screen, both horizontally and vertically. this problem came up instantly. Any ideas where i can look for this failure ? Unfortunately i...
This is either loose cable connection or faulty LCD. Try and take your screen apart. It's pretty easy normally get rid of all the screws and take plastics apart. Look for loose cable connection and resit any visible connectors. If this isn't working you more likely need new monitor. Good Luck
Apr 28, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
MY ASTAR TV screenshows vertical color bands and its non responsive
If you still have the TV, the remote has to be re-set. Hold the Enter button down approximately 10-seconds. It should re-set itself.
Dec 08, 2007 | Astar LTV-19BS 19 in. LCD Television
LCD 19" Samsung - one half od display has yellow vertical lines
This is surelly a internal failure in the LCD monitor. one of these 2 problems occured. Both of them will however require some profesional service repairs (if they even are possible) 1. You may have a faulty connection between the main board of the display and the LCD pannel. Even if only one wire or one singe pin isn't connected properly the results are pretty spectacular (weird lines on the display, lack of image or weird patterns appearing and so on) 2. The video controller chipset on the mainboard (inside the monitor) is broken and needs to be replaced (however it is a small chance you will find a replacement). I'm sorry if this isn't helpfull but the nature of the problem makes the diagnostic easy but the solving of this problem pretty hard. Good luck.
Feb 09, 2007 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dell E196FP 19" LCD Monitor Logo
222 people viewed this question
Clive
Clive
Alun Cox
