Question about Tomtom GO 910 GPS Receiver
I need to take my tomtom 710 apart but dont want to damage it
The brass pin inside tomtom 710 ar bent and I want to take this part out of the tomtom to repair with lots of space instead of the confined area while it is in the plastic case any advise as to were the fittings holding the unit in it's case would be great regards greg.
  • gregwhall1 Dec 19, 2008
    very helpfull thanks
    Master:
  • 479 Answers
As its quite risky doing this i will advise not to try trhis.but you can continue if u r confident as this is the link for the manual http://www8.garmin.com/manuals/nuvi750-GPS-Atl_OwnersManual.pdf
hope this helps.
Posted on Dec 15, 2008
  • 19,396 Answers
Computor does not reconise my tomtom go 910 satnav says formatting failed computor says usb device has failed
Power on the TT 910 and then press the Reset Button on the base of the TT. It is a tiny hole with a hidden button. use a rounded object, match end or soft pencil to puch the button. Then reconnect it to the PC and the PC will see the TT. Note that you may have to reload apps and maps depending on the state of the TT.
Nov 13, 2009 | Tomtom GO 910
How to open tom tom n14644??, usb is damaged need to replace surface mount part. star screws are all out but still case doesnt come apart.
Came apart eventually, click action!
Surface mount USB was a little tricky to remove, got there in the end and resoldered new part on.
If a Usb cable is inserted awkwardly the internal pins can be easily bent and damaged, rendering your device useless, good job i have experience with removing Usb's.
Sep 07, 2009 | Tomtom ONE 3rd Edition GPS
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Need car dock for tomtom go 710
Cheapest place to purchase a windsheild mount for the TomTom GO 710 is ebay.
Jul 14, 2009 | Tomtom ONE GPS Receiver
Karcher 2400: Won't stop spraying.
Dear sdadean,
I am assuming that when you said "wand" you mean the "gun". Myself I rarely service guns. But there are types that are serviceable and others that are not. If the brass elbow had 2 stainless steel pins....then this is a gun that you must replace with a new one. And putting oil, is the worst enemy....because oil damages O rings. Now the high pressure hose is fitted inside the brass part by being sealed by a black O ring and a white backing flat O ring. I do not know if these that you saw. Now if the brass has only one pin coming out from the back, this type of gun can be serviceable. Look at the brass at the place where the lance is attached. If you see a hexagon hole, this is a plug that can be unscrewed with an allen key. Behind the plug there is a ceramic seating. Then you find the valve and a spring. If the steel valve and the ceramic seating are damaged, the whole gun must be replaced.
To tell you the truth I usually change the gun and fit a new one, when the machine keeps on going because the gun does not close. I find it the best and the most safe way of solving the problem.
Regards,
Fulltech.
Apr 27, 2009 | Karcher 2500 PSI Pressure Washer
My TomTom 510 will not hold charge and now cannot be switched on
If you are not bothered about using it on battery your tt should work if you have it hooked up to a external power supply such as the car charger or home charger. If it doesn't work using either of the power supplies then your problem is deeper than just needing a new battery. Check the pins on the bottom of your tt to see if they are bent, or out of place. The most common problem for them is the negative pin on the far left with the lcd screen facing away from you gets bent or is not making contact even though the green light is on.
Hope this helps
Mar 06, 2009 | Tomtom XL 330 Car GPS Receiver
Carrier gas pack inducer motor
Sounds like you may have a bad connecton at the end, which end? if you follow the wires out of the motor they sometimes go to a MOLEX whitish plug. The wires treminate in this plug with PINS sometimes these PINS dont seat or come loose in the plug. Pull the plug apart and check the wires comming in from both directions. If they wont push or pull out of the plug either way they are seated ok. Check for a bent PIN while have it apart. If its worse and this dosnt fix it or its the end going to the motor consult www.carrier.com for a dealer near you. DO NOT USE A GENERIC MOTOR on your furncae as I believe it is a 2 speed and most generic motors ar only 1 speed. SOme of these gaspack motors have a centrifical switch and if this is your problem again consult with a carrier dealer. The price of the motor is secondary to safety and longvity of your comfort investment. If I knew where you lived I could make a better recomendation.
A viberation could mean a HORNET nest (using mud for their nest) could have been in place and reciently came loose and fell into the fan on the motor. carefully remove the assembly and inspect it for bent fan or shaft or maybe plastic and broken or metal rusted out parts.
If you need more information I need to know a few more things. If this helps you r not please grade accordingly and help me improve. THANKS AND GOOD LUCK.
Mar 02, 2009 | Goodman GMS90703BXA Heater
Tom tom go 710 wont switch on
Press the tiny reset button...
You'll need the pointy end of a paperclip or a pin.
Turn your TomTom upside down and look at the underneath, with the screen facing away from you.
Starting at the back and moving towards the screen, you'll see a small traingular-shaped piece of rubber, then a plastic area with a small hole to the left, then the circuit board with all the little gold connectors.
It's that small hole that's the reset button, push your paper clip or pin in there. Your TomTom should reset straight away, but sometimes it takes a few tries for various lengths of time.
Enjoy your newly restored TomTom!
Oct 29, 2008 | GPS
Tomtom 710 broken
What seems to be the nature of the problem?
Feb 01, 2008 | Tomtom GO 700 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
81 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
