Question about Microtek 211SD 21" LCD Monitor
Picture and video is not clear
I was givin a used microtek 211sd monitor that was not working i took it to a repair shop and when it was time to pick it up they turned it on it seemed to be good . i connected the monitor at home the desktop looks fine but videos and pictures comes out like a thermo type image i think i tryd every thing in the monitors menu and even downloaded a ATI catalyst control center nothing seems to help pictures and video comes out like a night vison kinda look theres no magnets around it accept for the built in speakers im not realy experienced in electronics so im not sure if its just something i have to confiure on my destop myself or if its a problem the repair shop shoud've fixed but befor i make a trip back there im hoping someone knows what im talking about and can help. thank you
  • 41 Answers
Hi Scandle201
Yot have done every thing right on your side. You will unfortunetly have to take the monitor back to the repair shop. Ask them to test it at your resolution settings of your home desktop and play some video's and open some pictures on there test system.
Regards
Go-Tech
Posted on Dec 15, 2008
Power saving mode
l connect monitor with any signal source
Mar 01, 2015 | Microtek 211SD 21" LCD Monitor
Ok here I go again. I have a 2006 nissan altima 2.5s. I took it to a shop a few months ago for inspection. It failed. After having it diagnosed they said it was the down stream sensor. The code I was...
Real simple
None of the shops you went to,
know how to diagnose a vehicle
I think your statement about one monitor,
is the evap system ,because they can test
the gas cap,the others have to run clear,
at least in New Jersey
Almost seems like the people that come to this site
Your shop just throw parts at the codes & no testing
to find a problem
If the problems are solved, you don't have to clear the codes
Clearing the MIL Lamp or check engine light, clears all data,
emission monitors,& freeze frame data set at the time fault
codes are set,so you got nothing to work with to find a problem
So never clear fault codes after a repair,let the monitors do their thing
All sensors are aftermarket sensors-so that is nonsense
That should have been a clue to forget that shop
The same companies make sensors for everyone,
new vehicle or used
Vehicle manufactures stamp sheet steel & make bodies
& assemble purchased components only
Nov 03, 2014 | Cars & Trucks
When pluged in just the green light powers green then fades yellow but the sceen never lites
It is acting like it is not getting the video signal from the PC, unless there are problem inside the monitor, you should try it with another PC. All the cables are good?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 13, 2011 | Microtek 211SD 21" LCD Monitor
Microtek scanner 3800
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:microtek@files165.cyberlynk.net/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works.
I managed before to do it with simple install but well, it works .. ;)
Apr 27, 2010 | Microtek ScanMaker 3800 Flatbed Scanner
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
Microtek scanmaker 3800 windows 7 compatible
Apr 02, 2010 | Microtek ScanMaker 3800 Flatbed Scanner
Microtek c593 monitors. Out of Range
Your Minotor not support windows 7 frequincy or resulation.please open your computer safe mode, and set monitor frequincy only 60Hz. Resulation less area .Then solve your problem.
Dec 27, 2009 | Microtek C593 15" Flat Panel LCD Monitor
MicroTek LCD Monitor
Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor.
May 29, 2008 | Microtek 211SD 21" LCD Monitor
Monitor makes popping noise when power is on.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 19, 2008 | Microtek 211SD 21" LCD Monitor
Microtek 211SD 21" LCD Monitor Logo
81 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
