Question about Technics SA-DA8 Receiver
Technics SA-GX130 turns itself off
I have this machine since 1997 and it worked perfectly well until several days ago when it started turning itself off after 5-10 minutes of use. Then it turns on, then 2-3 minutes later turns itself off again. No problem with the sound, the fan works fine. Any idea about the problem? Thanks.
SOURCE: Technics receiver SA AX540 overheating
is the fan turning on? many models like these have a cooling system (fan) that kicks up when the volume is turned to a certain level. if your fan has never been on, then chances are some of your soldering points have shifted or gotten a little messed up over time from the heating/cooling effect. this model runs extremely hot especially right where the vent is on the top of the cabinet. make sure that it is not in a shelf or enclosed area. dont stack other items on top of it. use an external device to control the volume so that you can have the receiver volume at a fixed level where the fan will turn on. if your sound still doesnt work, you should consider buying a new receiver or try your local craigslists forum. make sure if you buy a new one, that it is a more expensive model from a brand like sony and check the model online for known problems. stores like best buy offer extended warranties on most of their products which are very wise investments. good luck sinbad
Posted on Sep 19, 2007
SOURCE: Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Posted on Sep 28, 2007
petraman7
  • 1175 Answers
SOURCE: Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Posted on Mar 12, 2008
  • 92 Answers
SOURCE: Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Posted on Oct 14, 2008
djproaudio
  • 515 Answers
SOURCE: Over load on Technics SA-GX130
There is no easy fix for this. Your unit is power itself down to protect itself. There is an obvious short. You will need seek professional assistance.
- OPTiC
Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
CAN I USE SA-GX130 RECIEVER WITH IPOD
Yes, you can. Go to a local electronics store or go online and buy a cable (we used to call them patch cords back in the day) with a 1/8" STEREO plug, (also called a mini phone plug) on one end and two phono plugs (also called RCA plugs) on the other end. They're available in various lengths -- 12" is a good choice. We're talking less than $10 here.
Connect the RCA plugs into an appropriate pair of unused INPUT jacks on the back of your receiver -- CD, VCR1, Tape Monitor/VCR2 will do. DO NOT use the phono jacks. The red plug is for the right channel. You can leave the cable plugged in. Then whenever you want to listen to your iPod, insert the mini phone plug into the iPod's earphone jack, switch the receiver to the input for the cable, and start playing. You may have to increase the volume on your iPod to avoid having to turn the receiver all the way up (or down) to listen, but after that you can use the receiver's volume control.
Oct 28, 2014 | Panasonic Technics Sa-gx130 Receiver...
Older technics SA-GX100 sometimes left or right speaker will not work until volumes is cranked up
buy some turner cleaner or electrical contact cleaner(radio shack) with the power off take the volume knob off spray into the area where the knob goes(the little metal post) turn the post back and forth with your fingers or needel nose plyers several times (over time dust and dirt build up makes a bad connection) you may have to do this a couple of times dont worry this stuff drys realy fast this should do the trick
Sep 06, 2014 | Panasonic Technics Sa Gx100 Amplifier...
Stereo receiver: headphones work but speakers don't
This could be either a fault on the headphone socket itself, or on a speaker switch. It depends on how the insertion of the jack plug into the socket affected the sound before the fault. If for example the sound was cut off from the speakers, then it's likely the fault is the socket itself.
On the other hand if you have to press a button to switch the speakers off the fault will be connected with the that button.
Mar 28, 2010 | Technics Audio Players & Recorders
Technics SA-GX130 No manual to instruct on programming the preset station buttons
once you tune to a station just press and hold the button till it sets.
Jan 09, 2010 | Audio Players & Recorders
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Feb 18, 2009 | Technics SA-DX950 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Over Load light turns on and then we have no sound
please disconnect each speaker one by one and test it until you find the bad one-start with cable change and then the speaker itself.
Jul 04, 2008 | Technics Audio Players & Recorders
- OPTiC
A DJ Pro Audio Co.
Jan 26, 2008 | Technics SA-AX540 Receiver
Technics SA-DA8 Receiver Logo
394 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
