Question about Carrier BCA101R Air Conditioner
Carrier Thermostat Model TSTATCCPB501 ER code
Can the thermostat be manually reset to fix the ER code for a Carrier Thermostat Model TSTATCCPB501?.
  • Anonymous Mar 19, 2014
    doesthe carrier thermostat have batteries nd if they do how do you open the therostat to make themaccessible
  • Anonymous Mar 27, 2014
    tried power off and on, holding down temp up and down buttons comes up with 00.00. But when power on button pushed it shows Er 86
I gave up and called a local HVAC business. This thermostat is discontinued and a new one will be purchased and installed.
Posted on Dec 16, 2008
Problem with AC thermostat
You are correct about the "er" message. Best bet is to check your user manual for error codes and then take it from there. If nothing in book it is possible that the answer might be on manufacturer web site.
Could be issue with thermostat itself if the other zone is being cooled properly.
Aug 05, 2016 | Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Ac model # 42sd6b er-05 code meaning
Are you trying to run your cooling now? I'm guessing you have a carrier thermostat and that's where this is displaying. It's been awhile since I've came across one but to my vague reculiction that code indicates the outdoor sensor detects low ambient them temperatures which in turn will not allow your air conditioner to run which would make sense this time of year. If you want to run cooling in below 60 degrees temps you must add a "low ambient kit" this shuts the fan down outside to build up higher head pressure without doing this you will just ruin your ac but in your case it won't let you. Google up your Tstats model number and codes if that's not your situation.
Nov 24, 2014 | Carrier Heating & Cooling
How do you re-set error code for "change filter" when filter has been changed on Carrier programmlbe thermostat
Clean Filter Feature -
The thermostat will display the CLEAN FILTER indicator when it is time to change the filter. Press the Reset Filter button to restart the timer after the filter has been changed or cleaned. Helpful?
Dec 28, 2010 | Carrier TSTATHCP Programmable Thermostat...
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
Error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Error Code Er FF
Replace the defrost heater and defrost thermostat in the freezer.
Mar 23, 2009 | Kenmore Refrigerators
Carrier BCA101R Air Conditioner Logo
1,329 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
