Question about Dryers
GE Dryer sometimes it drys and other times stays cold
Sometimes it dries the clothes at other time it never gets hot to dry them.
    Scholar:
  • 111 Answers
If it's a Harmony, you have a bad blower motor. If other than Harmony, you could have loose wires to the main terminal block (where the power cord connects) or an intermittent circuit breaker. Model number would be helpful...
Posted on Dec 16, 2008
My dryer only works sometimes model #ggw9200w1
I would 1st check and see if the vent pipe assy is clogged up with lint.
GL
Sep 14, 2014 | Whirlpool Dryers
MY DRYER WILL NOT DRY THE CLOTHES WHEN I USE THE REGULAR CYCLES. I HAVE TO DRY THE CLOTHES ON TIMED DRY FOR 90 MINUTES AND THEN SOMETIMES THEY ARE NOT COMPLETELY DRY. THE DRYER IS DEFINATELY GETTING HOT,...
Your vent system is more than likely stopped up..You may have to pull the dryer out and clean the flexible hose that connects the vent to the outdoors
Apr 12, 2011 | Dryers
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer dosen't dry my clothes
Check the exhaust tube for obstructions. If this is a gas dryer it needs airflow coming and going through that tube. This is always the cheapest, easiest first step.
Sep 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Dryers Logo
136 people viewed this question
Top Dryers Experts
Marvin
Marvin
