Question about Toshiba Satellite M45-S265 Notebook
Dropped my laptop and now it wont boot up, the power lights for the electrical connection and power on indicator light up when the power button is pressed, also the HD lights come on for a second.The three light in the top right hand corner flash once. But that is all, nothing is show on the screen at any point. There is not physical damage to the laptop, it just fell out of my lap.Please help
    Sergeant:
  • 324 Answers
Probably something got knocked loose during the fall. As a first step, remove and reinsert the hard drive and memory module(s). Those seem to be the most common things to come loose. If that doesn't work, you will need to get under the covers of the laptop and reseat all of the cards and connectors.
Here is a link that shows you disassemble the M45.
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
Hope this helps and gets you backup and running. Have a super day!
Ron
Posted on Dec 15, 2008
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
Power indicator light comes on my laptop but no display and system will not boot andmyou can'tnget it to reload or get in to system bios.
Any damage? Drop? You get Nothing? No fan spin? No LED's blink? Nothing? You didn't supply the Toshiba model or the OS? How old? Is it time to replace the CMOS battery?
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Wont boot up. Just beeps every 5 seconds and a
Is the beep a moderately high tone that lasts for about two seconds? If so, this is the firmware loading signal, which sounds only when the power button is held in on powerup. This would indicate that your power switch has a mechanical or electrical problem and is not releasing.
If this is not what you are hearing, please provide more detail.
Jun 18, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Lenovo 3000 c200 wont power on
try to perform battery drain. you need to take out the battery and unplugged the power adapter. press and hold the power button and count 1-10. release the power buttong after 10. do it for 3 times. after that, plug in the adapter and power adapter and observe.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 25, 2010 | Lenovo 3000 C200 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Pavilion dv6000 when power button is pressed,
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
Jun 19, 2009 | HP Pavilion dv6000t Notebook
Laptop wont boot
am sorry to say that laptops are more delicate falling from your laps could course alot of damage on the motherboard please visit your nearest service center for help
Dec 15, 2008 | Toshiba Satellite M45-S265 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
