Question about Belling Ovens
Cooker problem i have changed the element in my belling farmhouse cooker and the oven still isnt working what else can be wrong with it
  • Belling Master
  • 3,463 Answers
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Posted on Dec 15, 2008
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Tip
Belling Elements
on Aug 25, 2010 | Belling XOU592 / XOU593 Electric Double...
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
Tip
on Aug 25, 2010 | Belling XOU482 Electric Double Oven
Tip
on Aug 25, 2010 | Belling XOU252 Electric Single Oven
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Tip
on Aug 25, 2010 | Belling XOU174 Electric Single Oven
Tip
How to diagnose, fit and change a Belling fan oven element.
on Aug 25, 2010 | Belling XOU270 / XOU271 Electric Single...
Ovens Logo
283 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
