Question about Echo 3 TE SL7 3 New Electric Scooter by Shoprider
Not running - full battery
Shoprider scooter- got stuck in the mulch, we pushed it over mulch to sidewalk without changing the freewheel lever. The battery is fully charged, the lights come on, the wheel acts like its engaged but it does not run. In flipping it over, the freewheel switch moves freely but the shaft that goes between the wheels (axel?) turns freely by hand even though the wheels are engaged. Does this mean that the motor thinks the wheels are disengaged? Did we damage it by pushing it without disengaging the wheels? Where can we go to have it serviced? We're in Jacksonville Fla. 32224. My sister is absolutely dependent on the scooter. I need help.904-223-0813
  • Echo Master
  • 1,272 Answers
Hi look up www.americanmobilityscooters.com in Jacksonville FI 32211 ...Cheers
Posted on Apr 06, 2017
I have a elite mobility scooter why does it stop on me my battery are fully charged the lights go on but won't move
Hi check freewheel lever at the rear of scooter if U an push the scooter it's in freewheel :::::: push the lever lever the other way to lock it in gear .. Cheers
Nov 25, 2016 | Elite Health & Beauty
I have a shoprider dulux and all lights work all fuses work but scooter wont move forward or back checked the free roll lever and break they both good and in right position please help
Hi just check to c if U have freewheel lever in correct position if U can push the scooter it's in freewheel ,::::::: push the lever the other way so it locks into gear check to c if it's locking in gear :::: if U can't push it it's in the correct position,.., Cheers
Nov 22, 2016 | Shoprider Health & Beauty
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
I installed new batteries and scooter still doesn't run,why?
Check the wiring from the controller to the motor, disconnect the wire ad clean the connections with a contact cleaner or WD40 , and make sure the scooter not in freewheel mode.
Regards
Dec 14, 2012 | Shoprider Scootie
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
My echo 3 scooter beeps as soon as I turn on the power. It shows a full charge, but there is no response when I push the lever. The brake is released. The horn works.
Boy I hate working on scooters too many things can go wrong to make them not work. First make sure you are not in freewheel Make sure the lever at the rear of the scooter is in drive position. and you can't push the scooter easily without powering it up. If its not in freewheel then the problem could be a throttle pot problem or a speed pot problem or even a motor problem and there is no way I can troubleshoot your problem in this format. I would suggest that you have your provider check it or if Medicare paid for it have a repair service fix it for you. Sorry can't really give you a precise answer on whats wrong Good Luck Hope this helps
Nov 19, 2010 | Shoprider Echo 3 Wheel Scooter
Shoprider sovereign when switching on and pressing reverse scooter will not move but reverse bleeper sounds nor will scooter move forwards. switch off and on again and on then works correctly
If the freewheel lever has been operated while key is in on position the scooter will not operate until key is turned off and then on again, make sure freewheel lever is in drive position. hope this helps.
Jun 29, 2009 | Kitchen Appliances - Others
Echo 3 TE SL7 3 New Electric Scooter by Shoprider Logo
48 people viewed this question
Top Echo Health & Beauty Experts
Rob Hill
Rob Hill
Bill Boyd
Jeff Tilburn
Jeff Tilburn
Are you an Echo Health and Beauty Expert? Answer questions, earn points and help others
