Question about Olympus Mju 780 Digital Camera
Hello I have a problem with my Olympus digital camera 780 all weather, it doesn't come on any more. I have charged the battery but it still doesn't come on. Any help will be appreciated. Thanks.
SOURCE: why my camera wont turn on?
Hello.
When the two led's blink, that is telling you that the batteries are dead. Try replacing the batteries with FRESH ones and that should help.
NJ
Posted on Jan 24, 2008
  • 504 Answers
SOURCE: How to recharge battery of Olympus FE-280 Digital Camera
When you purchased the camera, there should have been a charge in the box (you got a lithium-ion rechargable battery with the camera, no?). You put the battery in the charger and plug the charger in the wall.
Posted on Mar 12, 2008
sumthin
  • 71 Answers
SOURCE: Olympus FE-280 Digital Camera problem
I had the same problem.
First the obvious, Is your charger actualy charging? Have you tried another Battery?
Sometimes the charger led turns green, when it actualy never charged the battery.
Jiggle the battery around to make sure it is seated securely. If in doubt find a friend with a Volt meter (VOM ) and check that the battery voltage is 3.7v to 4.0v when fully charged.
Assuming that you now have a fully charged battery. it's time for a little house cleaning. Use a Q-tip and Isopropal alcohol .99 cents a bottle. (Not Rubbing, it contains lanolin).
Gently clean the contacts on the charger and the battery. You dont need a lot. A little dab'l do ya. You can also clean the contacts on the charger with a pencil eraser if they look a little corroded.
Now it gets a little more fun. Look down inside the camera battery compartment and make sure the spring contacts are sticking up far enough to contact the battery, also make sure the battery eject spring is not bent and interfering with the contacts or the battery.
If you feel confident, gently, very gently, clean the contacts in the camera.
Only wipe towards the center once or twice. If you wipe the other way, you will have
cotton fibers wrapped around the contacts. not good ! If you do not feel confident cleaning inside the battery bay, Dont!....... send it to Olympus. I hope that does the trick for you. Nice taste in cameras by the way. Sumthin
Posted on Apr 03, 2008
danjmet
SOURCE: after charging the battery i put it in my camersa and it reading batttery empty
This happened to me before and its because i put the battery in the charger the wrong way up. Make sure you put it in so that the side with OLYMPUS in it in big letters is facing up!
Posted on Apr 25, 2009
  • 6 Answers
SOURCE: My Fe- 280 olympus digital camera will not turn on
CAN BE A DEFECTIVE CAMERA SEND IT TO THE REPAIR THAT YOU HAVE A WARRANTY AT.
Posted on Aug 11, 2009
Olympus all weather 760 errors 5f08 5f0a 5e02 Blue error message lens will not retract makes burring sound help please
The sound your camera is making, is probably the slipping from the gears, grinding them down, because something is blocked. Even when you can't see any blockage. Please don't leave the battery in, to avoid more damage. Contact a certified Olympus repair centre, or visit your dealer with the camera.
Sep 17, 2014 | Olympus Stylus Stylus 760 µ Digital 760...
Trouble downloading pics from olympus 780 to mac laptop running sys 10.7.4
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Sep 01, 2012 | Olympus Stylus 780 µ Digital 780 Digital...
No charger
The camera doesn't come with a charger. It uses standard AA batteries. If you use rechargeable batteries then you must charge them outside the camera using a separate battery charger. Rechargeable AAs and charges should be available at just about any department, electronics, or office-supply store.
Jul 18, 2012 | Olympus Camedia C-350 Digital Camera
Where can i buy a charger ?
I have a Olympus -[mju:] 780. My husband, (soon to be EX) has taken my computer and with it all the software for my camera
Go to the manufacturers website and download the software you need for your camera for free. After downloading, install the software on the pc you want to use with the camera and then either connect to the computer with a cable or insert your memory card to view photos.
http://www.olympus.com
May 24, 2011 | Olympus Mju 780 Digital Camera
I need a replacement charger for my digital camera Stylus 780/u 780 Where can I order one?
If you are in India, you can check out here to buy elinchrom studio light product in ArihantDigi.com. Its the website for shop lights for your studios.
Mar 04, 2011 | Young Micro 2n1 - Neoprene (Neon Green)...
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Why my camera wont turn on?
Change your batteries. buy a new set
Nov 24, 2007 | Olympus FE-115 Digital Camera
Olympus Mju 780 Digital Camera Logo
24 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
