Question about Bose Lifestyle SA-3 2-Channel Amplifier
Bose amplifier does not work with a 6 speaker selector
I have a Bose lifestyle surround sound system. My house has speakers built into the walls in 4 of the rooms. I wanted to tie these house speakers into my Bose system. I hooked up the SA-3 amplifier and ran the house speakers to a speaker selector box. I connected this to my aplifier, but it doesn't work. There is no sound at all. I know my amplifier is set up properly because I tested one set of the speakers directly to the amplifier and it works. When I run the speakers through the speaker selector box, there is no sound. I'm not sure what ohm the speakers are, but the speaker selector box controls 4, 8 or 16 ohm speakers.
    Problem Solver:
  • 11 Answers
Your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Posted on Mar 19, 2007
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Best amplifier for bose 901 VI speakers
By all-in-one amplifier that handles the surround I think you mean all-in-one receiver or preamp. Amps are just big dumb muscular power supplies for speakers.
The source control and digital decoding could be handled by a modern AV receiver with multichannel analog outputs for driving separate amps or you could get a digital AV preamplifier/control unit functionally like this Adcom. Prepare for sticker shock.
http://hdtvdreams.com/Adcom-GTP-870HD-7.1-Multi-Channel-Processor/Preamplifier-GTP870HD.aspx
Understand that EACH PAIR of Bose 901's will require its own DEDICATED two channels of amplification AND someplace to jack in its Active Equalizer - between the line level source and the power amp.
Conventional speakers can probably run off the receiver's amplifiers since they don't/can't/must not have the Bose Active EQ in line with them.
Having a single pair of 901's plus a passive subwoofer or two in the same room for accurate 6- or 7.1 surround would require at least four stereo amps or some combination that adds up to 8 channels.
In my own system I have a Pioneer VSX-36TX Receiver (with 5 potential channels of amplification for Left, Right, Center, two Surrounds) doing light duty as the control and routing center but ONLY driving the Center (two Kenwood 777's) and Surround speakers (Bose 301's). I have a Carver 5-channel amp pushing the Bose 901 Front speakers (100Wx2), two dbx Subwoofers (110Wx1) and the Bose 301 Rear Surround speakers (60Wx1).
You could probably get by with a powerful 2-, 3- or 4-channel amplifier to push the 901's and subwoofer(s) as I did. It's the cheapest way out if you get a decent AV receiver. Once you set up the levels and delays the receiver does all the thinking and controlling for you.
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Bose Lifestyle SA-3 2-Channel Amplifier Logo
631 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
