SOURCE: I cannot pair my Nokia N95 with HBH-608 Akono headset
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
SOURCE: Sony Ericsson W900i Pairing With HBH-608
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
SOURCE: Pair my Sony Ericsson bluetooth
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards,
Carlos
Testimonial: "Thank you for the info. I don't think that the Sony is compatible with my Pantech. My Jabra connected with no problem, but the Sony would not."
Press and hold down the headset volume key in the centre. Hold it for about 5 sec. The led will now flash on/off in red. This is the pairing mode. Set your mobile phone to blue tooth discovery mode,until it finds the headset, key in the pass key, 0000. It should now work. You may need to set the phone to select the headset as an automatic connection so it connects whenever it is on and in range.
SOURCE: My Sony Ericsson Bluetooth headset
www.sonyericsson.com/.../HBH_PV703__UG_R2a_EN_DE_ES_FR.pdf
