Question about Whirlpool AWM5125/1 Front Load Washer
Whirpool AWM5125 faults
No power light.
You can hear the timer slipping straight to the next cycle.
But if you turn the power off the timer cycle switch doesnt move
No Water
Thanks
  • 41 Answers
You need a new timer
Posted on Jun 12, 2010
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
May 09, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Kenmore refrigerator (bottom freezer)
U MAY HAVE BLOWN THE COMPRESSOR RELAY DUE TO THE TRIP? U CAN REMOVE IT FROM THE COMPRESSOR AND SHAKE IT IF U DONT HAVE A METER TO TEST IT, IF IT RATTLES THEN ITS BAD? IF THERE IS A CLICKING WHEN COMPRESSOR IS TRYING TO RUN ITS BAD, OTHER WISE I WOULD SUSPECT A BAD COLD CONTROL THERMOSTAT ESPECIALLY IF UR TURNING IT FROM UNDERNEATH AND NOT JUST THE KNOB? DID U USE A SCREWDRIVER TO GET INTO THE TINY SLOT UNDER THE TIMER AND TURN IT SLOWLY TILL U HEAR A CLICK? TURN AGIN AND THE NEXT CLICK SHOULD TURN IT BACK ON U SHOULD HEAR THE COMPRESSOR AND THE FAN WORJKING
Mar 14, 2015 | Kenmore Refrigerators
Amana Washer NTW4501XQ0. I have replaced the lid switch, and the timer. The washer still will not run thru an entire cycle. What should I try next
You can try recalibrating unit. With your dial setting at the 12 o'clock position on the timer, you want to do these steps within 7 seconds. Turn timer knob left one time, 3 rights, one left, one right.
Then you will see all the lights blink. ( no time constraints after you see lights blink) Turn the knob 4 clicks to the right, then push the start button. Let it run until you hear the lid unlock and you see the done light lit up. When you replaced the timer, you needed to recalibrate the unit.
Feb 25, 2015 | Amana Washing Machines
How to fix a whirlpool washer
Move the timer on up to the spin cycle and see if it spins. If it doesn't spin and it is a top loader that uses a belt to turn the agitator and the tub for spinning, then more than likely your belt is broken or slipping. If you hear the motor turning and nothing is happening it's likely the belt.
May 20, 2014 | Whirlpool Washing Machines
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Whirpoll AWM 6000 does not take water.
What to check next is the water inlet valve. To do it, turn on the machine and start the filling cycle. If you cannot hear a faint buzzing or humming noise from the water inlet valve, the solenoid coil is not getting any power. Check it's wiring. If you can hear some noise, you need to replace it. Make sure to unplug the unit before doing any service.
Oct 18, 2009 | Whirlpool Washing Machines
Whirlpool Top Load Washer cycle problem
check the lid switch by putting a screwdriver into the lid switch hole; look at your timer duration diagram it's in the control panel a small sheet of paper taped inside Does you machine not advance mark the timer knob and, see how far the knob advances next set the timer for the agitate position and check the timer for continuity on those pins noted on the sheet
May 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWM5125/1 Front Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal De
